I know lotsa folks out here use the 743/347 saws and was wondering if anyone had run DC to the little 1" ID port or otherwise set one up for vacuum or DC.
I used some homemade adapters to connect my Fein shop vac to my PC. It works much better if you put a little "skirt" on the front of the saw to direct air flow. The dust port feature of this saw is why I bought it.
I live in my own little world. That's OK. Everybody there knows me!!
Thanks, DD. Was wondering if vacuuming the port would do it, or if I needed a sweep in front of the blade.
I found 3/4" pvc just about the right outside diameter to fit the PC's dust port, just a hair over 1" (may have to shave it a bit).
Trying to come up with a solution for it and my pc router, which has a 1" OD dust port. After spending a couple hours at the borg running from plumbing to electric to shop vac ailses and test fitting every pvc pipe, hose, and adapter I could find, I came across 1" ID flexible spa hose. Perfect for the router port, and the 3/4" pvc fits it good & tight. Unfortunately, HD's 1 1/4" shop vac hose adapters are about 1 1/8" OD, while the spa hose's OD is 1 1/4", but a 1" PVC coupling joins the spa hose and shop vac adapter pretty well.
