Bosch Jigsaw Edge Guide
  • Stormbringer
    • 1387
    • Floral Park, NY
    • Bosch 4000
    Anybody have the edge guide for the Bosch Jigsaws? I'm trying to get one for my 1590 but can't seem to find one locally (HD, Lowes etc..)...or on-line for that matter.
    Why they can't include a $4 edge guide with a $160 jigsaw just rubs me the wrong way.
    TIA,
    Greg
  • Jeffrey Schronce
    • 3822
    • York, PA, USA.
    • 22124
    TIA,
    Greg
    Sears has one that works with their Bosch clone. They are clearing out the Bosch clone, so you may be able to get the guide cheap . . . . or it may not be there having been cleared out?
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      Greg, I'm curious as to why you want one?
      I realize that they're two different tools but years ago when I bought my circular saw I also purchased an edge guide for it. At the time, I fugured it would be handy and a good thing to have. I have yet to use it once in all those years.
      • Deadhead
        • 490
        • Maidens, Virginia, USA.
        I have one, but haven't had the need for it yet.
        The main reason I got it was to use as a circle cutter. And I only bought it when I did because Amazon was having a deal with a minimum purchase and the guide got me over the minimum.
        As a edge guide, I would be more likely to use a straight edge as a fence.
        "Success is gettin' what you want; Happiness is wantin' what you get." - Brother Dave Gardner (1926-1983)
        • steve-u
          • 222
          • Bartlett, Ill.
          • Ryobi BT 3100
          Amazon has it. When I got mine I think it was just under $10. Now it is near $20 [maybe because they only have one left?]. If you check Amazon often you will probably see it drop down again. The second link shows a Google search link for it that shows other sellers. -- Steve
          http://www.amazon.com/gp/product/B00...lance&n=228013
          http://www.google.com/search?hl=en&q...=Google+Search
          • Stormbringer
            • 1387
            • Floral Park, NY
            • Bosch 4000
            Jeff,
            Thanks for the suggestion, I'll check Sears.
            Greg
            • Stormbringer
              • 1387
              • Floral Park, NY
              • Bosch 4000
              Dave,
              It just seems to be one of those situations. I'm building a fireplace mantel and surround. After deciding on how I wanted the columns (uprights supporting the mantel shelf) and after building the carcass, the wife decides to change the face of the columns a tad .
              Bottem line, she's looking for a "recessed look" to the column so I have to cut out the center lenght (3" X 4') of a 6" X 4'.5" wide board. Then the inside edges will be given a decorative edge with the router. Not a cut for the circular or table saw but an ideal cut for the sabre saw. Unfortunately, the piece is just too narrow to accomodate clamping a straight edge and the jigsaw comfortably. If I can't find the edge guide, I'll just free hand it and clean up the inside edges with a straight bit and the edge guide on my router before hitting it with the ogee bit.
              Steve, Thanks for the link. Ouch! $20 for what probably will be a one time use is a little too steep for me. But we'll throw it in our cart anyway to see if it drops.
              Regards,
              Greg
