I noticed that you cannot adjust the height of the bit from above the table unless you first unlock the motor from the base. Are you suppose to reach down unlock the motor then adjust the height from above the table then reach back down and lock the base again? If that's the case then I don't see much use for the above table adjustment feature on this router. Then again I can be totally confused. Can someone please clarify this for me?
Thanks.
Thanks.
