Solved my straight-edge issues
  • bigsteel15
    • 1079
    • Edmonton, AB
    Stopped by Metal Supermarkets and picked up a 6 ft and 8 ft lengths of 1-1/2" x 3/16" aluminum FB. Perfectly straight from what I can see. Matched side to side they appear to have no gap. Will check it out
    Brian
    Welcome to the school of life
    Wow, what do you need that long a straight-edge for?
    -Phil
    • final_t
      • 1626
      Guessing a sheet of plywood.
      • bigsteel15
        • 1079
        • Edmonton, AB
        -Phil
        Cutting 4x8 sheets of plywood lengthwise accurately is a little difficult on TS.
        I use my CS but have had problems finding a decent 8 ft straight edge.
        Brian
        • ryan.s
          • 785
          • So Cal
          That's a great idea. I did the same thing a while ago and it works great. I'm now looking to get some aluminum angle for router table/drill press table fences.
          • Stick
            • 872
            • Grand Rapids, MB, Canada.
            I use Al angle too for circ saw and router straightedges. On the drill press I use steel, just because I had it laying around. I work more with metal, so my DP table is bare steel most of the time. I drilled and threaded holes every inch in a 3 foot chunk, so I can bolt it to the table and also bolt a stop to it.
