What clamps do you most often use?
what is favorite type of clamps?
229Handscrew2.62%6Parallel jaw clamps16.59%38Black-pipe clamps6.11%14Deep throat black-pipe clamps0.87%2Aluminum bar clamps13.97%32F-style clamps (over 6")16.16%37Small f-style clamps (under 6")6.11%14Spring clamps6.11%14C-clamps3.93%9Quick-grip24.89%57Vise1.75%4Clamps? Clamps are for sissies0.87%2Last edited by Wood_workur; 05-07-2006, 07:02 PM.AlexTags: None -
In addition to the Clamps mentioned above, I also use Surgical Rubber Strips to hold irregularly shaped things together while the glue dries, as well as Band Clamps
The kind of Rubber Strips that are tied around your arm while they draw blood at the hospital.
Last edited by gmack5; 05-07-2006, 09:29 PM.Stop thinking why you can't and Start thinking how you CAN!
George -
I also use large rubber bands a lot. I have those 1” wide kind in various lengths and I find them to be exceptionally handy. I blame Jim Boyd for that as I picked up the idea from him, course, I blame Jim Boyd for a lot of things!Comment
I probably use masking tape more than my clamps. I initially use a clamp to squeeze the pieces together and then use the tape. That way I can take the clamp off and use it somewhere else.- Dennis
"If your mind goes blank, don't forget to turn off the sound." --Red Green
and yes, it's a potato.Comment
Originally posted by kwgeorgeI also use large rubber bands a lot. I have those 1” wide kind in various lengths and I find them to be exceptionally handy. I blame Jim Boyd for that as I picked up the idea from him, course, I blame Jim Boyd for a lot of things!
Jim in Texas and Sicko Ryobi Cult Member ©Comment
You forgot about a 5gal bucket filled with something heavy. I used a couple of those and some 3/4 ply to glue the laminate flooring down as my workbench top.David
Besseys . . . .
From Amazon . . . .
Cheap . . . . .
(When they don't screw the order up!)
Seriously, all around I don't think you can beat a good range of K-Bods or Cab Masters. Jets new entry looks very nice as well.
Only real draw back is weight and cost.Comment
I use used bicycle innertube tires cut into long strips, cheap and disposable if need be. They are great for clamping irregular shaped work. You have the option of cutting them thinly for light work or wide for that which needs a bit more strength.
RComment
Listed as quickgrip, though it is another brand, of the same thing. For YEARS, all I ever knew was pipe and c clamp (and the later was from brake jobs).She couldn't tell the difference between the escape pod, and the bathroom. We had to go back for her.........................Twice.Comment
