Just a heads up for DeWALT DW733 planer owners. Yesterday I noticed snipe . . . a lot of snipe. Turns out that one of two hex screws on the each of the tables had worked loose and fallen out. I replaced the one I found using "locktite" to, hopefully, secure it. The other is probably in the vacuum. The nuts were not listed on the parts diagram or list. We have a DeWALT repair shop and, while they didn't stock the item they were able to ID it and order. Ordered two pair, just in case.
The two remaining hex screws were somewhat loose. Used "locktite" on them also. I'd suggest checking them reqularly. I usually do a nut and screw testing/tightening on tools when I give them a good cleaning. Never gave a thought to those two little buggers though, as I hardly ever raise and lower the in/out feed tables.
