1/2" shank drum sander spindle
  • jwaterdawg
    • 656
    • Washington, NC USA
    • JET
    Anyone know where I get drum sanding spindles (mandrels) with a 1/2" shaft? I need to be able to chuck them into a drill press and the spindle needs to be long enough to accomodate a ~4" (preferrable 4-1/2") rubber spindle.
    The closest thing out there that I have found is Grizzly product H4331. It is described as having a 3/8" shank, but nothing is mentioned about the shaft diameter; from the picture it looks like 1/2" shaft. Anyone out there have this and can comment on the shaft diameter?
  • jwaterdawg
    • 656
    • JET
    So, I am now posting a reply to my own query
    I called Grizzly; indeed the shaft of that mandrel is 1/2".
    However, if anyone is aware of other similar mandrels I would still be interested. The Grizzly ones may just fit in length but it will be close since the drums/sleeves I have are 4-1/2" whereas the Grizzly mandrel is for a 4-1/4" drum. Thanks.
    • Bruce Cohen
      • 2698
      • Nanuet, NY, USA.
      Jay, try this, it comes from Lee Valley. com. I got one and it works great.
      Best
      Bruce
      Samuel Colt did"
      • jwaterdawg
        • 656
        • JET
        Bruce,
        Thanks for your post but I am confused about whether that Lee Valley drum kit will work for me. I should probably clarify:
        I have a bunch of 4-1/2" rubber drums and sleeves; probably about a dozen drums of various sizes and close to 100 sleeves of different grits/sizes. I got these at a great discount several months ago. The drums all are meant to be mounted on a mandrel with a 1/2" shaft size.
        Thus I need a mandrel or spindle with a 1/2" shaft size, approximately 4-1/2" in length + shank for chucking in a drill press.
        So, are you saying that the mandrel (spindle) that comes with that Lee Valley drum will work for me?
        Thanks,
        Jay
        • Bruce Cohen
          • 2698
          • Nanuet, NY, USA.
          Jay,
          Sorry, I misunderstood what you wanted. The Lee Valley drum sander takes 3" sandpaper sleeves only. Its a complete unit. I suggest surfing for a dealer that specializes in turning equipment. I know that lathes have shankes and mandrels that could be modified to work with your existing drums.
          Possible if you pose the question in the "Turners Forum", you might get a lead on where to get what you're looking for. That is, if it even exists, which it probably does. Have you checked out the entire Lee Valley on-line catalog.
          Good luck, sorry I couldn't be of more help.
          Bruce
          Samuel Colt did"
