cheap framing nailer???
  • Russianwolf
    • 3152
    • Martinsburg, WV, USA.
    • One of them there Toy saws
    anybody know of a cheap framing nailer? I don't care if it's reconed or new, but looking for something dependable. The cheapest I've found is a Harbor Freight for $60.
    I need to finish a deck and am tired of driving screws one by one.
    Lakota's Dad
  • greencat
    • 273
    • Grand Haven Mi
    • 3100
    I have the HF framing nailer and am happy with it. Purchased last year to do some deck work and used it last night again with no problems. I screwed in my deck boards because I didn't trust normal nails. If I had shank nails I would skip the screws. The nailer did help do temporary supports while I got items level before I could go back and put in screws. Maybe it was over kill but I would recommend the HF.
    Thanks again,
    • wreckwriter
      • 449
      • South Florida
      I prefer screws in a deck due to nails working up eventually. How about one of these new gadgets: http://www.blackanddecker.com/Produc...ProductID=9460
      http://www.wreckwriter.com/
      • gmack5
        • 1972
        • Quapaw, Oklahoma, USA.
        • Ryobi BT3000SX & BT3100
        One of those gadgets the wreckwriter referred to is available from Amazon.com (ASF100EX) for $49.95.
        Holds 20 screws at one load, not too bad, if it works.
        Here's the scoop: http://www.amazon.com/gp/product/B00...lance&n=228013
        George
        • wreckwriter
          • 449
          • South Florida
          Yea, that's the trick: if it works.
          I've seen them in Lowes but never seen one in use. seems a good idea though.
          • Shipwreck
            • Mar 2005
            • 85
            Framing nailer?
            Even the best deck nails, shanked or not will be a problem in the future. Teflon coated screws are the way to go. Nails are fine for a production guy who has to do 3-4 decks a week, but for some one who wants quality and tight boards................... he should use a good deck screw.
            Just my opinion.
            • Jeffrey Schronce
              • 3822
              • York, PA, USA.
              • 22124
              I have used the HF 21 Degree 10 gauge nail gun quite a bit in last couple weeks. Only problem is that about every 3-4 sticks of nails the last 2 will not fire and I must take them out. I have no idea what is causing this but really wasn't that bothered by it.
              However, I would stick with premium screws. Square head or star head are the easiest to use. Improved Phillips head is ok. Regular phillips takes too much work.
              • Crash2510
                • 830
                • North Central Ohio
                have the 6 in 1 framing nailer from HF have only put a couple hundred nails through it but it works great only complaint is that it is very heavy
                Phil In Ohio
                The basement woodworker
                • agent511
                  • Jun 2005
                  • 257
                  • Philadelphia
                  • TS3650
                  If you are looking for a cheap framing nailer, I don't think you will find one in the universe cheaper than Harbor freight. And they work remarkedly well.
                  But as far as decks, regular nails - or regular screws - are not used because they will rust and ruin the deck. You need special nails or screws - either galvanized dipped nails or stainless screws for example. Someone mentioned teflon coated screws - I am not familiar with them but if they are rustproof then that is another to add to the list.
                  Do they make rustproof nails for pneumatic framers? I don't think so, but I could be wrong.
                  darksider
                  • ExYankee
                    • Mar 2005
                    • 126
                    • Pleasant View, Tn.
                    • BT3100-frankensaw
                    I have one of the B&D screw feeders and it works GREAT, I was doing hardi-backer on the floor and was dying even with the gel pads so I went and got one. The only down side was it would not take the hardi screws( too big a head) but the coated square drive deck screws feed wonderfully, I thought it would be a hassle but it just keep feeding and driving screws
                    John Dyer
                    ExYankee Workshop...
                    I think history would have been very much different if Leonardi DiVinci had a belt sander.
                    • onedash
                      • Mar 2005
                      • 1013
                      • Craftsman 22124
                      anyone remember some fancy trick they did on this old house? You couldnt even see the screws and it automatically spaced the boards with the same gap. I thought it was pretty cool when I saw it but cant think of what they actually did. I think it was Tom Silva doing it.
                      • BizCoach
                        • 93
                        • Milford, CT.
                        There are two cheap HF framing nailers - this one one has variable angle and no depth control
                        http://www.harborfreight.com/cpi/cta...emnumber=91044
                        This one is fixed at 21 degrees and has depth control.
                        What are the pros and cons of depth control?
                        www.CEOBootCamp.com
                        Tools to help you run your business better
