Recommendations for first hand plane
  • kwgeorge
    • 1419
    • Alvin, TX, USA.
    I kind of went through this some time ago. I had read many horror stories about the “Contractor” grade Stanleys at like Lowes so I bought a Groz at Rockler. What A POS! When trying to use it my hand constantly hits the little lock lever and it unlocks the blade! So I have to stop everything and deal with that. Also there is a lot to deal with before you can use a purchased plane and be happy with the results. So do your research on this subject on the net as if it is not prepared properly it is worthless.
    I think myself that the best general use plane there is in my shop is my Block plane. I reach for it a lot!
    My .02
    • MPod
      • 169
      • Lenexa, KS, USA.
      I have these two planes that have served me very well.
      This Jack Plane:
      http://www.leevalley.com/wood/page.a...56&cat=1,41182
      And this block plane:
      http://www.leevalley.com/wood/page.a...=1,41182,48942
      The Jack is a great all around plane. Long enough to effectively joint edges and short enough to smooth. This is a great plane that doesn't require any tuning to use. Just hone the blade and you are good to go.
      The low angle block gets a lot of use and is much more comfortable than my late model stanley block plane that has now been relagated to knocking glue off of mdf.
      There are a lot of very strong reviews on the Veritas Planes.
      This is the one I want next:
      http://www.leevalley.com/wood/page.a...30&cat=1,41182
      I always used to consider myself more of a machine guy until I purchased these planes. Effortlessly whisking transparent shavings off a piece of wood with a high quality plane has a calming effect that I can't really put into words.
      I also recommend reading the handplane book. I purchased it myself recently and couldn't put it down. A great informative read.
      -Mod
      Measure with a micrometer, mark it with a crayon, cut it with an axe.
      • drunkcat
        • 116
        • Elgin IL
        • BTK
        I am hoping for one of these in the near future.
        http://www.lie-nielsen.com/catalog.php?sku=60_5R
        If you will have a limited collection, I think its a good one because it doubles as a block plane and a rabbet plane. I have use one and is great for trimming down tenons.
        Here is (one of) the original designs of this plane:
        http://cgi.ebay.com/Sargent-507-bloc...QQcmdZViewItem
        • gchapman
          • 44
          • Rochester, MN, USA.
          Slippery Slope
          It's a slippery slope. I picked up a garage sale Stanley 4c plane which I fixed up and then got a Knights Jointer plane. They are great to have. The best source I have found is the Woodnet discussion group. Knowledgeble folks and extremely open to help out. Also some guys sell refurbished planes.
          Glenn
          http://www.forums.woodnet.net/ubbthreads/ubbthreads.php
          \"I see,\" said the blind man as he picked up the hammer and saw.
          • Tom Miller
            • 2507
            • Twin Cities, MN
            I have a construction-grade Stanley block plane (low-angle, but mouth is not adjustable). It didn't take much tuning beyond a good blade sharpening to get it to work well, and is a real workhorse. Partly because it didn't cost an arm and a leg, and partly because it isn't any kind of heirloom, I don't hesitate to use it on anything and everything.
            Then, I got a Veritas Low Angle Jack. It was spendy, but it works nearly out of the box (I honed the blade). It'll perform lots of functions, from shaving end grain on a shooting board, to jointing, even to face smoothing. Like a block plane, the LA Jack is very user-friendly; no steep learning curve to get good results.
            Regards,
            • germdoc
              • 3567
              • Omaha, NE
              • BT3000--the gray ghost
              After having had a hundred or so planes pass through my hands over the last few years, I would rec. getting a Veritas LA block as my first purchase. It does 90% of the planing I need.
              Next, I would think about a #4 bench plane--preferably Veritas, but could try a vintage Stanley on Ebay. I've also read good things about Footprint planes sold by Rockler--might need a little fettling.
              For sharpening I would get a combo 1000/4000 wetstone and one of those cheapo sharpening jigs.
              I hate to admit this, but after I got most of my handplanes I started using a good belt sander for most of my rough work--flattening tables, etc.--using my block plane mainly for finer finishing stuff. But I love my block plane--have accessory handles and chamfering attachment.
              Jeff
              • mschrank
                • Oct 2004
                • 1130
                • Hood River, OR, USA.
                fettling, frogs, hock blade....
                I have no idea what any of this means. Maybe I'll stick with a belt sander
                BTW-I'm not asking for explanations for the terms...when I finally decide to take the plane plunge, I'll figure it out.
                • brumere
                  • 54
                  • Thousand Oaks, CA, USA.
                  • 1968 Rockwell 12/14 Tilting arbor saw
                  #23
                  I have over 50 different planes in my garage - mostly old stanleys. The plane that easily sees the most use is the #60 1/2, low angle block plane.
                  Deep in the Darkside
                  • vaking
                    • 1428
                    • Montclair, NJ, USA.
                    • Ryobi BT3100-1
                    #24
                    Just came accross these planes on a closeout. I never tried this style and already have smoothing and jack planes, otherwise I would have been tempted. Anybody tried Euro style wooden planes?
                    http://www.woodcraft.com/family.aspx?familyid=5049
                    Alex V
                    • Tom Miller
                      • 2507
                      • Twin Cities, MN
                      #25
                      My first thought was that the blade alone would be worth the price -- then I read the description of the blade....
                      "They both feature carbon steel blades with brazed on HSS cutting edges."
                      Regards,
