Square for checking tool setup.
  • ryan.s
    • 785
    • So Cal
    What type of squares do you guys use when checking the setup/alignment of your tools. I've been using speed squares and framing squares but to get really accurate readings and better ease of use I'm thinking a machinist square is more appropriate? Are most brands of machinist squares pretty true or do I need to get an expensive one. Are the HF ones any good?
    http://www.harborfreight.com/cpi/cta...emnumber=39047
    Thanks!
  • LJR
    • Jan 2005
    • 136
    I have a set of plastic drafting triangles in the shop which I use for setup. They're cheap, accurate, and come in quite a range of sizes. And if I drop one on the floor I don't panic.
      Same here. I keep a 45, a 30/60, and an adjustable triangle in the shop.
      • kwgeorge
        • 1419
        • Alvin, TX, USA.
        My personal preference is to have 1 high quality engineering square that everything else is referenced against. Never has the need for such become more obvious than awhile back when I decided to take a look at a Craftsmen $25 tri-square I had bought. Seems the cheap aluminum was not machined properly and it was not at 90 degrees to the ruler. I have since salvaged the ruler and threw the rest away.
        I am not saying that cheaper tools are necessarily a bad thing but when it comes to a measuring device you should be confident that it is accurate so that you obtain the predicted results. So buy a good square and use it to check others and when tuning a tool.
        My .02
        • markmt
          • 69
          • kathleen, georgia, USA.
          I ave these squares and have checked the accuracy on a granite slab at work (aerospace industry). They are within 0.010" tolerance. I was pleased nd shocked. They are worth the money. You can teke them to a machne shop and have them checked and toleranced.
          Good Luck
          Mark Taylor
          • Tom Miller
            • 2507
            • Twin Cities, MN
            I've been very happy with these:
            They're from Lee Valley; you can see them here.
            Regards,
            • scorrpio
              • 1566
              • Wayne, NJ, USA.
              I managed to snag a good deal on a Starrett combination square on ebay, but I also have a http://www.grizzly.com/products/G9787 from Grizzly, and it is a very well-made set. All three heads are hardened cast iron, ruler is hardened steel, etched, so it the scale on protractor. Zero flex anywhere, and square head is dead square. All-metal construction, there are no plastic parts.
              Overall, I'd stay away from plastic and cheap aluminum. Those plasting drafting triangles might be fine, but I prefer to put faith into brass, hardened steel and cast iron. A good mark of quality is etched, rather than stamped, markings.
                A machinist friend of mine said for woodworking, he'd recommend one of the cheaper sets from Enco. Should be well within woodworking tolerances.
                • woodsmoke
                  • 28
                  • Pablo, MT, USA.
                  I use different sized drafting triangle. Cheap,accurate,can be modified easily if needed, and like tape measures I can have several laying around so I don't have to worry about where I left it last time (always one hangin round somwhere).
                  If it is impossible just give me a couple more days.
                  • scorrpio
                    • 1566
                    • Wayne, NJ, USA.
                    Gross misconception. Joinery that's not dead square will come out crooked. It does not matter much if ALL rails in your panel doors are 1/32" short - but if their ends are not square, your doors will look horrible.
                    • BobSch
                      • 4385
                      I've never had any luck with drafting squares. Try a set of Machinist's Squares Griz has them for less than $17 http://www.grizzly.com/products/H2993
                      If you want to check Whatever you're using, try this:
Name:	Square check.gif
                      Put your triangle on a straight edge in position (1) and mark the bottom (A) and top (B) then flip it over, put the bottom on the A mark and the difference at B is TWICE the error (If any).
                      Bob
                        I will also vote for drafting triangles. Besides being as accurate as any of the other alternatives and being cheaper, they are also somewhat soft so they will not damage a carbide blade if not used quite correctly. I do not use the drafting triangles for layout, I would prefer something else for that but for tool setup, I think they are ideal. My normal layout tool, for the few times I put lines on something, is either a steel ruler or a conbination square (checked for accuracy and known to be accurate). For long measurements I use a tape measure (again, one I checked so I know it is at least roughly accurate).
                        While I agree that things go together much better when built square I would also add that the concept of square includes the concept of straight. Few pieces of wood are exactly straight - and if they are they may not be with a humidity change. We should make things as straight and square as possible but also realize wood is not steel and that is a good thing.
                          $40 for a set that the tolerances were .0008", if that's not square enough, what are you working with?
                          • scorrpio
                            • 1566
                            • Wayne, NJ, USA.
                            .0008 is good, and $40 is not exactly a 'cheap' set when compared to some $10 set out there. I did not look up Enco sets, I was simply referring to the statement that 'woodworking does not need to be so precise'.
                            Wood might warp a bit out of straight and square over time, but at the moment of glue-up, you really want it to be straight and square. Just like wood itself, wood glues allow for some flex, so a small amount of warp is fine after proper bond is established. But for that, original assembly must be very precise.
