DeWalt planer trouble
  • ted van halen
    • 76
    I borrowed a buddies 12.5" Dewalt planer for taking various widths(3" - 8") of heart pine to desired thickness. My max depth of cut is 1/32. On the wider stuff I'm only taking 1/64 per pass. It has started "skipping" intermitintely on the feed roller. It makes a slight clicking noise & hesitates almost like a gear is missing a tooth or something. I quit w/ it immediately when I noticed the problem as it is borrowed. I made the owner aware of what's going on & he asured me it had never done that before. Lucky me. w/ the planer on I can actually see the feed side roller hesitate every now & then. It's not consistent at all & I'm not sure if the outfeed roller is doing it as well. The cutter head doesn't seem to be affected but at 10K RPM I could be wrong The owner also has asked me to take it apart to investigate as of the 2 of us, I'm the more astute one for the job.
    Any of you guys ever seen something like this? Any advice? Any questions? Any answers?
  • Jim Boyd
    • 1766
    • Montgomery, Texas, USA.
    • Delta Unisaw
    I've heard of the sprockets messing up on the older Dewalt planers. On mine I had a feed problem and used simple green to clean the feed roller and the amount of gunk that came off was shocking. Worked like new after cleaning. I hear pine is bad about gumming up the feed roller.
    • just4funsies
      • 843
      • Florida.
      That clicking noise does indeed sound like a flat or missing gear tooth. If it's flattened out, it will engage the opposing tooth head-on, and the click will be heard when the gears slip back into mesh. You might see if there is a parts diagram online for your unit, and that might give some clue where the gears are, and how best to sneak a peek.
      • ted van halen
        • 76
        Update for feed problem
        I took the side cover off this bad boy tonight. The power feed is chain driven, not a direct gear drive so that simplifies things a little. There's a primary drive off the motor to the outfeed side & a secondary drive off that to the infeed side. I took the drive apart & looked at the gears. They don't show a lot of wear & actually still have a slight burr on one side of the teeth. The other side is rounded like you would see w/ normal wear. I think the chain is just stretched out. There is a LOT of slack in it. I did lube it up good that seemed to help. I'll suggest to my bud that I continue using it until I'm done & then he can order a new chain & I'll install it. Sounds fair to me.
        • just4funsies
          • 843
          • Florida.
          I'm surprised there's no idler arm or some sort of tension adjustment for the chain.
          • ted van halen
            • 76
            Me too. I'm gonna take a second look but there isn't a whole lot of room in there for one. I didn't see one on the parts diagram either so...
            • Ken Weaver
              • 2417
              • Clemson, SC, USA
              • Rigid TS3650
              Did you clean the rollers while you had things apart? Denatured alchohol works fine and pine does gunk things up quite a bit. you may a combination of things going on between the chain and the rollers.
              Ken Weaver
              Clemson, SC
