Rookie jointer question
  • ksu93
    • 44
    • Topeka, KS
    OK, so I finally got around to buying a jointer this past week, and tried using it for the first time today (the first time I've ever even been close to a jointer that's on). Once I got the outfeed table aligned with the cutter blades correctly I thought all I really needed to do was push the piece of wood across and keep it pushed down on the outfeed table. Is that not right? I ended up with a curved edge that looks kind of like a boomerang. I'd sure appreciate any pointers you all might have. Thanks.
  • rickd
    • 422
    hi,
    you might want to have a look at this article which explains pretty much everthing about aligning jointer blades:
    http://www.woodcentral.com/bparticle...justment.shtml
    hope this helps.
    rick doyle
    Rick's Woodworking Website
      Double check your alignment, making sure the tables are coplaner to each other. Then grab some scrap wood and practice, practice, practice. A jointer is a simple tool but has one of the biggest learning curves.
