This is one interesting observation.
In order to cut laminate flooring, I replaced the stock blade in my BT3100 with a 7.5" CS Freud 40T blade. The frst thing I needed to to was rip 2" off several sections (whch are about 4' long). On first two rips, the blade would bind once or twice through (though the saw did not appear to be 'laboring'), but lifting the piece off and then re-feeding it and going slowly would complete the rip just fine.
After second rip, I noticed that blade was coasting a lot longer than usual. I checked it, and found out that blade was not tightened - it was rotating free on the arbor! Not sure how that happened - I thought I tightened it properly. What is amazing is that blade was sharp enough to rip 4 foot long laminate boards on nothing but friction between arbor and blade.
Sure enough, after proper tightening, I had no more cutting problems, even with fairly aggressive feed rates. And after numerous rips and crosscuts installing ~300 sq ft of laminate, the blade shows no signs of wear.
