Picked up my new SCMS
  • Jon The Buddha
    • 48
    • Oklahoma City, OK
    Well, I got the 10" GMC SCMS today. This is my first miter saw of any kind, so I can't compare my initial impressions with anything. I will say that I am seeing a couple of problems.
    Out of the box, the blade was nice and square to the table, but it was a bit off from the fence. No biggie, I figure, just needs adjust. I loosened the bolts for the fence and began to adjust. I found that it seems to square up best when the left-hand portion of the fence is full forward (in it's range of play), and the right-hand portion of the fence is full back. I hope the way I'm explaining it makes sense. Does that sound plausable??
    The other issue has to do with cutting at a full 45 degree miter angle. I was test cutting 2x4 scraps, and found I couldn't get a full through cut. The blade travel consistently left about 1/4 to 1/2 inch of material. Is this consistent with other saws? The specs seem to indicate that this should not be a problem. I made sure the trench adjustment wasn't the problem, but there is another allen screw next to the trench height adjustment that appears to possibly come into play. It is not referenced anywhere that I can find in the owners manual, and there is no adjustment instructions for the screw. I decided not to mess with it yet.
    Next problem is with the laser. It is incorporated in to the saw body, not to the blade area like other saws I looked at. The line is off by a good 1/8 of an inch, and there is no alignment instructions for it in the manual. There is also no screws or adjustment point anywhere close to the laser itself that I can find.
    Lastly, I don't like the way the stops for the common miter angles are done (0, 15, 22.5, 30, 45) . They are not really stops at all. Instead of locking firmly in place when you hit the angles, it is more like a shallow groove that you can feel, but still lets you go past. When you get it into the grooved area, there is still a tiny bit of play in both directions. Other saws I have looked at lock firmly into place at the pre-set angles with no play what-so-ever.
    Maybe all this is nit-picky, I don't know. Like I said, this is my first miter saw so I don't know what is normal. I'm wondering if I should take it back and get the Ridgid 10" CMS like I originally planned. I want the MSUV, so I am going to HD anyway, and they have the BT3100 on sale for $249. Perhaps I should just pick them all up and sign up for the card to get the extra 10% off. Where is that phantom 20% off coupon when I need it!!! JUST KIDDING!
    Oklahoma City, OK
    "What do you mean 'it isn't really 2 inches by 4 inches'??"
  • Andrew Benedetto
    • 1071
    • SoCal, USA
    http://www.heavydutytools.net/Script...?idproduct=183
    Bosch SCMS for $263
    Andrew
    • Jon The Buddha
      • 48
      • Oklahoma City, OK
      Originally posted by Andrew Benedetto
      Nice find, thanks.
      Have you bought from them before? Are they respetable? I buy plenty of small stuff online, but usually make important purchases locally, simply because returns online can be a real PITA (I hope that acronym is known here ). I know I could save a lot of money on my big purchases, but I am always worried I will run into the kind of problem I now have, and it take months to resolve. It seems everyone likes Amazon.com, so maybe I will reconsider.
      Any opinion on my problems with the saw? It could well just be the user!
      Oklahoma City, OK
      • Andrew Benedetto
        • 1071
        • SoCal, USA
        Yes very good to deal with. A SCMS is a power tool not to buy cheap. I have a makita ls1013l, but the bosch is a good saw too, esp. for that price. 10" blades are much cheaper and can be more accurate than a 12",I would not buy a 12",too expensive. Here is a test,
        http://www.toolsofthetrade.net/artic...ticle&partID=1
        page 2;
        Tool Weight Amps Rpm Deck Height Cut Capacity Street Price
        Bosch
        3915 47 lbs. 13 4,700 3 1/2" 90°: 3 1/2" x 12"
        45°: 2 1/4" x 12" $429
        Comments: The Bosch 3915 performed flawlessly. The slide motion is extremely smooth. The saw adjusts for bevel and miter cuts and locks into those positions easily. The allen wrench needed to adjust the table fence comes with the saw, as does the blade-changing wrench. Both tools secure to the saw body for easy accessibility. The saw body is as boxy as an old Volvo and takes up more table and truck space than I'd like, but it drives like a BMW. www.boschtools.com
        Andrew
        • Stormbringer
          • 1387
          • Floral Park, NY
          • Bosch 4000
          Awsome Deal
          $263 for this saw (after applying the discount code) is an incredible deal. (Shipping to NY was only $17). Amazon is selling it for $389. 12" crosscut capacity and only 46lbs.
          Even though I have the DeWalt 706 (great 12" non-slider btw) I'm tempted to pull the trigger on the Bosch for this price.
          Please buy these up before I enter my credit card info.
          Greg
          • Jon The Buddha
            • 48
            • Oklahoma City, OK
            Greg
            I'm about to take the twins to the park, so I'll have to order it later. Save one for me!!!!
            Oklahoma City, OK
            • Jon The Buddha
              • 48
              • Oklahoma City, OK
              DANG!!!!! It is now showing "out of stock"!!!!
              Oklahoma City, OK
