6 1/2" Stacked Dado
  • gmack5
    • 1972
    • Quapaw, Oklahoma, USA.
    • Ryobi BT3000SX & BT3100
    6 1/2" Stacked Dado
    The only place I've seen a 6 1/2" Stacked Dado mentioned is on this Forum!
    Has anyone EVER seen one offered for sale?
    If so, where and by whom?
    George
  • Holbren
    • Oct 2004
    • 709
    • Orange City, FL.
    I did a quick search and actually found one by Ryobi for the BT3000, it was not for sale anymore though. Also found an Irwin but same thing.
    Brian
    www.holbren.com
    • gmack5
      • 1972
      Thanks, Brian.
      I got the same results when I tried Google.
      George
      • woodyork
        • Jan 2005
        • 37
        • Payson, AZ.
        6 1/2 Freud
        I have a 6 1/2 inch Freud SD206 stacked dado set that I bought at Amazon.com about 2 months ago. Great blade -beutiful flat bottomed cuts.
        Easy to assemble with penty of spacers and a convenient chart to get you close to the width you want.
        Too soon old,
        too late smart
          I have the Forrest Woodworking 6.5". It cost a small fortune, and I barely ever use it. Cuts clean-bottom dados with minimal tear-out. But stacked dados take a long time to setup. So I use a router for dados these days.
          Thanks,
          Phil
          • monte
            ***** Windbag
            • 5242
            • Paw Paw, MI, USA.
            • GI 50-185M
            6" seems common size for dado set. I don't think I've seen a 6 1/2" set.
            Monte (another darksider)
            • monte
              ***** Windbag
              • 5242
              • Paw Paw, MI, USA.
              • GI 50-185M
              The SD206 is a 6" set and not 6 1/2".
              • Holbren
                • Oct 2004
                • 709
                • Orange City, FL.
                George,
                Out of curiosity, why the extra 1/2"? Just more depth on a saw that can't take an 8" set?
                Brian
                www.holbren.com
                • woodyork
                  • Jan 2005
                  • 37
                  • Payson, AZ.
                  Yep the Freud is advertised as 6". I thought it was 6.5. mea culpa.
                  Actually I went out and measured mine and it measures 6.25. I can't see why it would make much difference. After all what's a 1/2 inch between freinds!! --
                  Woody
                  Too soon old,
                  too late smart
                    Thanks,
                    Phil
                    Woops, my Forrest is a 6", as well. Just proves that I had more money than brains, and now I have neither. ;-)
                    • gmack5
                      • 1972
                      Here's why I'm looking
                      Originally posted by Holbren
                      George,
                      I'm thinking of putting together a Torsion Box workbench Top made with 2 X 4 (3.5") spacers.
                      A 6" Dado set won't do the trick and an 8" set is NOT recommended for the BT3X00 Table Saw.
                      A Saw Blade can "expose" 3 9/16"ths on a 10" Saw Blade, which means that 2 7/8" is needed for the center portion of the Blade and not available for cuts.
                      A 6" Dado Set gives you the following Depth-of-cut numbers: 6 - 2 7/8 = 3 1/8" devided by 2 = 1 9/16" (Depth of Cut on a 6" Dado set).
                      To Half Lap a 2 X 4, you need to cut a notch that is 1 3/4" deep, or 3/16ths more than a 6" Dado is capable of cutting.
                      I own a 6" Dado Set (SD206) and it won't quite make the trip!
                      Hence the inquirey about a 6 1/2" Stacked Dado Set.
                      My only other choice is to reduce the Spacer height by 1/2" to 3", not something I really want to do if I can help it.
                      George
