rotary hammer
  • parnelli
    • 585
    rotary hammer
    Trying to hang some shelving in the basement, and after half a hole with my cordless, and half a hole with a corded drill I've decided I need to buy a new tool.
    Did some searches here and found that the $29 HF hammer drill has some supporters. http://www.harborfreight.com/cpi/cta...emnumber=45338
    I also saw a thread from dgreco3917 last fall that said he had switch problems with the $35 3/4 rotary hammer.
    http://www.bt3central.com/showthread...highlight=2957
    http://www.harborfreight.com/cpi/cta...temnumber=2957
    Assuming (I know what they say) that the problems were a fluke- what's the benefit to the sds rotary hammer? I read online that sds bits won't slip and that the 2957 hammer also has a hammer only mode that can be used with a chisel.
    Which overall is more useful? Is the hammer function that helpful? Next year I've got a hallway of ceramic tile to rip up- would it be easier with the 2957?
  • just4funsies
    • 843
    • Florida.
    Using a hammer-drill and a nice fresh carbide-tipped masonry bit will definitely be easier. I use my DeWalt cordless, and go through concrete so fast, it's scary. I get a lot of stuff from HF, but I don't own any of their handheld power tools. I have heard some for, and just as much against, their quality. I tend to err on the side of caution, especially with all the sales, factory recons, and coupons floating around for the name brands.
    • parnelli
      • 585
      just4funsies- do you know what the difference is between a regular hammer-drill and one of the sds hammer drills even if they're not HF?
      • maxparot
        • 1421
        • Mesa, Arizona, USA.
        • BT3100 w/ wide table kit
        I have the 1" HF SDS hammerdrill. It's served me well so far. Yes it has a hammer only mode for using chipping chisels. SDS bits have slots that lock them in place.
        Opinions are like gas;
        • just4funsies
          • 843
          • Florida.
          SDS hammers are for drilling much bigger holes... the kind you might use a mini-sledge and star bit for otherwise. The SDS hits with much more force, and would jar loose any smooth-shank masonry bit, hence the need for the slotted bits. Since you are hanging shelving, I assumed you were not needing a hole bigger than 1/2". If you do, use an SDS. If not, a hammer-drill will do just fine.
          • parnelli
            • 585
            A-ha! as the light bulb finally goes on. Now I get it-
            I went by and picked up the HF hammer drill tonight and got lucky- it was on sale for 26.99 in store. Haven't had a chance to try it out yet.
            • DaveStL
              • 100
              • St Louis, MO, USA.
              • Jet 10: Xacta RT
              I destroyed a hammer drill on my basement wall-- kept hitting aggregate and rebar. Bought the little Bosch rotary hammer and went through it like a hot knife through butter, and the bit didn't heat up much. The difference is a hammer drill has a metal-on-metal drive mechanism, and the rotary hammer is hydraulic.
              Wish now I'd bought the next size up, because the small one has no chisel mode (useful for tearing up tile and scarifying (sp?) concrete, and its capacity is listed as 3/4" which will limit you if you want to run conduit. The bigger one cost about a third more, though.
              Dave
