Depth Stop - HF Mortiser
  • Lonnie in Orlando
    • 649
    • Orlando, FL, USA.
    Have any of you improved the depth stop on your Harbor Freight mortiser (#35570)? The plastic pinch clamp depth stop slides too easily to be effective.
    [image]http://www.harborfreight.com/cpi/photos/35500-35599/35570.gif[/image]
    edit -- looks like I can't display the image on the HF site, so here's the link ...
    http://www.harborfreight.com/cpi/pho...5599/35570.gif
    Looking for a simple fix that doesn't involve drilling the body of the mortiser. Otherwise, I guess I'll cut blocks to size and attach the column between the body and the base. Perhaps with a screw to fine tune.
    Thanks,
    -Lonnie
  • ssmith1627
    • 704
    • Corryton, TN, USA.
    This mortising machine is on sale right now so I've been looking at it.
    Did you find any solution to your problems? Is it worth buying ? Or should I hold out until I can afford a different model ?
    Would love to hear your opinion of it after you've been working with it a while.
    Thanks,
    Steve
    • Lonnie in Orlando
      • 649
      • Orlando, FL, USA.
      Steve:
      For my level of use, the HF mortiser works fine --- especially at the price w/20% off coupon.
      My fix for the depth stop isn't pretty, nor is it adjustable. But it elimated slipping. I cut a piece of PVC to the height that I needed. Split it down the middle. Wrapped it around the support column between the base and the plastic stop. Held the two halves together with tape.
      Lonnie
