HF trim router - worth it?
  • jarhead
    • 695
    • Boynton Beach, FL.
    For those that have Harbor Freight's trim router... is it worth the $20? Can a trim router be used to cut the dovetails or is it underpowered for the task?
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    I wouldn't use it to cut dovetials, BUT...
    I have one that cost 10 times that amount
    Use it for hand-held stuff that the 1/4" collet can handle. Assuming the thing is "reasonable" quality - I'd buy at least 2.
    Surely for $20 ea you can't go wrong
    Downunder ... 1" = 25.4mm
    • Popeye
      • 1848
      • Woodbine, Ga
      • Grizzly 1023SL
      I bought one last spring and took it back because the hole in the shaft for the collet was drilled off-center. May have just been that one but... I ended up buying the Ridgid. I use the thing alot, great for doing small round overs and just about anything that I'd use a handheld router for. Pat
