Wanting to buy the GRR-Ripper, but first...
  • dxcoded
    • Oct 2003
    • 89
    • nashville, TN, USA.
    • ridgid ts3612
    some questons for the users. I am trying to figure out if it is worth it to buy the gr200 or the original? I am going to buy 2 so I can use it for longer stock. I am about to start making a kitchen countertop so these will come in handy. Does anyone have any advice as to which one I buy?
    thanks
    eric may
  • just4funsies
    • 843
    • Florida.
    If in doubt, always get the fancy one...
    The one I use most is the standard configuration, but the side-pressure pad (from the Grrripper Plus kit) comes in handy when I'm on the router. The Grrripper takes a little time to fine-adjust for best fit on different jobs, but gives great feel and control when done properly. (I can't believe I said that, because I used to be one of those guys who starts grabbing for the pusher with one hand on the work, and the saw already running...)
    • ErikS
      • 214
      • Woodbridge, VA, USA.
      My only question about the gripper is "why did I wait so long"?
      Been using it for a year - love it. You couldn't give me any other push device.
      Buy the upgraded version, the side support comes in handy often. On the router table, ripping thin pieces, etc.
      • just4funsies
        • 843
        • Florida.
        Careful! Using the side piece when ripping on the TS is not recommended! The side pressure can push the cutoff into the trailing edge of the blade and cause kickback. Maintain ONLY down pressure.
        • ErikS
          • 214
          Correct.......and I should have been more clear. No side pressure, the "shoe" is only used for extra stability. I use the set the "shoe" so that it's not in actual contact with the piece being ripped.
          Thanks for telling me I wasn't clear - hate to give invalid/dangerous information.
          • just4funsies
            • 843
            • Florida.
            I figured you really knew, Erik, or you wouldn't have enough fingers to type the message...
            Sidenote to dxcoded: Woodcraft sometimes puts the GrrripperPlus on sale at $20 off. If you're gonna buy 2, that's a pretty good deal.
            • dxcoded
              • Oct 2003
              • 89
              • ridgid ts3612
              Thanks so far for the answers! So is it worth buying 2 of the 200 or should I save a few bucks and buy one 100 and 1 200 model? thanks for the tip on woodcraft that would be a great deal I will keep an eye out for that deal....hopefully they do this soon since I need to get these soon. Wife is ready for some new countertops and I am ready to get some more "toys"!!!
              eric may
              • Wood_workur
                • 1914
                • Ohio
                • Ryobi bt3100-1
                I have one, and I love it! I would get the fancy ones, only because you will then have the extra stuff if you need it. The only argument against them is that you can't use a guard with them, but you can't use a guard for thin strips. I have ripped 1/2" wide strips, and noticed no difference in cut quality.
                Alex
                • lcm1947
                  • 1490
                  • Austin, Texas
                  • BT 3100-1
                  One of each
                  I first bought the original but soon decided a second was needed for long stuff so I purchased the deluxe model. Now I have the best of both worlds and saved a little money on not buying two of the deluxe ones.The deluxe model does have some capabilities that I can see will come in handy some time or other so do recommend getting at least one. I tell you they are truely great. The control you get from them is so comforting and you can even use them on the router table. I could go on and on but I think you get the idea. One of my better buys that I rank right up there along with the Shark guard and splitter.
                    I was at the woodworking show the first of this month (seems forever ago, can't wait for next year, already). When I was there, they had the models 100 and 200 out, and a new model that was a couple more additional pieces (seperately available for around $20). The model 200 was recommended for the tablesaw and Jointer. The new features were recommended for the band saw.
                    As you can tell by my post, there were more toys at the show, then my budgeted allowance would get me. If I had just won that last big powerball..... LOL
                    • just4funsies
                      • 843
                      • Florida.
                      If you don't hit the jackpot, you can just withdraw to the shop and make sawdust. The theraputic value of sawdust production is incalculable.
                      • softop41
                        • 470
                        • Plainfield, IL, USA.
                        GRRRR-ripper
                        I bought one thinking that maybe they would be OK but not really sure. It took about 2 uses to find that I really liked it. The next time Woodcraft had then for $20 off, I got a second one. It is now the only push block/stick that I use on the tablesaw or the router table.
                        HTH
                        Jerry
                        Jerry
                        • Knottscott
                          • 3815
                          • Rochester, NY.
                          • 2008 Shop Fox W1677
                          My Gripper with all the doodads was a gift and I really like it, but all I ever use is just the basic part.
                          • ErikS
                            • 214
                            An FYI - from the other gripper post:
                            Sigh.........I guess I should go back to lurking - man do I feel bad posting info that if not done with care could get one injured.
                            What I do -
                            If it's a small strip being ripped & a portion of the body of the gripper falls outside the edge of the cut off I use the apron to give the gripper a bit more balance. I do NOT have the apron in contact with the cut off piece - there is ALWAYS a gap between the apron & the cut off piece. This gap prevents any side pressure against the cut off which means it will not be forced into the blade causing kickback. The ONLY reason I use the apron is to provide a bit of extra balance - it is not necessary.
                            Disclaimer - I do NOT reccomend this approach, I recommend that you follow MicroJig's instructions & NOT use the apron when making rip cuts. I am not responsible if you injure yourself by choosing to ignore the manufacturer's instructions. If you use the gripper this way you are accepting the risk of being injured.
                            Here's a pic of what I mean:
                            • lcm1947
                              • 1490
                              • Austin, Texas
                              • BT 3100-1
                              Yes Eriks and to add to that caution allow me to mention that Grr-Ripper also recommends that the handle should always be directly over the blade.
