Hey guys, I'm too lazy to do my own research right now, so I thought I'd see what some of you might already know about this.
I'm about to add an extended table to my BT3000, and I'm thinking about building in a high-tech custom router table at the same time (then I can abandon the acc'y table router mounting). What does anybody think who has one of the fancy crank-up router lift insert plates, like the Jess-eM, Bench Dog or similar? Looks like they might be worth a look.
Also, I'm trying to figure out which of the routers I've got lying around to use, as the Ryobi I've been using is a bit underpowered. I have a new Hitachi M12V that I'd like to use, but I'm wondering if its plunge-only configuration might make it a poor choice, as the lift systems I have seen all seem to be made for a smaller motor, or one that can be removed from the handle/base (like a PC convertible type). Anybody got an M12V or similar mounted in a fancy lift setup?
I also can see that the soft-start thumbwheel switch on the M12V is going to be a pain to reach under the table, but I can live with that, I guess.
Discussion?
*****UPDATE***** Just found the Plungelift for the M12V on Woodpeckers. Anybody have one of these?
Discussion?
