Bandsaw Tires
    Bandsaw Tires
    I need tires for my 14" Ridgid bandsaw. Do these come in 14" size and will any kind fit? I can't find any locally.
    Woodcraft sells the neoprene that are supposed to be good.
      Thanks Pappy. I looked on their site and didn't see them earlier but I found them this time. I will ride over to Woodcraft in the morning.
      • monte
        ***** Windbag
        • 5242
        • Paw Paw, MI, USA.
        • GI 50-185M
        The neoprene ones are supposed to be better than the standard OEM tires from what I've been told.
        Monte (another darksider)
        • final_t
          • 1626
          Rocker has the better deal on these. Woodcraft sells them @ $25 each ($20 on sale). Rockler has them @ $26 pair.
          Didn't see neoprene tires, both carry urethane.
          • maxparot
            • 1421
            • Mesa, Arizona, USA.
            • BT3100 w/ wide table kit
            Neoprene is just a word for modern rubber which would require you to glue on the tire. Urethane is a synthetic replacement considered to be an upgrade. It should last longer and does not require glueing to the wheel. But I have no first hand experience with it.
            Opinions are like gas;
            • Tom Slick
              • 2913
              • Paso Robles, Calif, USA.
              • sears BT3 clone
              urethane are supposed to be the best. you soak them in hot soapy water and install them. when they dry/cool they shrink and are stuck. it is a bit of a pain to glue on rubber tires.
              check out www.carterproducts.com they make alot of great bandsaw products, including replacement tires.
                I bought 2 of these today at Woodcraft. I put them on this afternoon. They seem to fit good. The directions said to let them dry before installing the blade. I will put the blade on tonight and try it out.
                • mikel
                  • Jul 2006
                  • 202
                  • philadelphia
                  • bt 3100
                  I know this a little old but How did they work? Do you need to crown Urethane tires ?
                  ...mikel
                  • sacherjj
                    • 813
                    • Indianapolis, IN, USA.
                    I just put two of the Rockler orange tires on my Ridgid. They seem to fit almost perfect, but I had to "tuck" the edges in just a bit. Although, I have another problem. I didn't even think that the bottom wheel bolt would be left hand threaded and rounded off the threads on the bolt. It looks like I damaged the bolt more than the steel shaft, so hopefully I can just get another bolt. Hate it when I do something stupid that just costs time in the shop. I was hoping to try out my newly balanced wheels today.
                    Joe Sacher
                    • mikel
                      • Jul 2006
                      • 202
                      • philadelphia
                      • bt 3100
                      getting ready to mount my orange ones...
                      good info here
                      http://www.owwm.org/viewtopic.php?t=...rockwell+tires
                      • BigguyZ
                        • Jul 2006
                        • 1818
                        • Minneapolis, MN
                        Let me know how it goes, and any tips you may have. Once I complete my TS station the bandsaw is the next tool to get worked on.
                        • sacherjj
                          • 813
                          I put them in water hot enough that I couldn't keep my hand in for over a couple seconds. Let them sit for about 10 minutes. Put a couple drops of soap in the same water. Then I used 3 small clamps around the wheel and pulled the rest on. Then I worked around the wheel with the round shaft of a philips screw driver a few times to balance the pressure. After that, I just pushed in the edges to "tuck" them in. It wasn't too bad. After reading that link above, I'm wondering if I should pull them off and sand the 45 in it. It seems like i have a decent crown though. I'll have to think about that.
                          Joe Sacher
                          • mikel
                            • Jul 2006
                            • 202
                            • philadelphia
                            • bt 3100
                            Mine went fine. I did not sand them but they lay perfectly flat at the ends. I too did hot water and soap. Left the wheels on the saw and just streched the orange ( highland hardware ) urethene tire on my import 14" BS.
                            Runs great nice and tight. The aluminium wheels have a slight crown allready. The orange rubber sits even with the top of the rim. Nothing to crown really.
                            So far so good.
                            ...m
                            • mikel
                              • Jul 2006
                              • 202
                              • philadelphia
                              • bt 3100
                              here is the finished top wheel....
                              has a crown because the wheel is crowned.
                              ...mikel
