A somewhat different comment. It is not clear to me that you understand that the reason the nailer works over a fairly wide range of air pressure is because it also works with a fairly wide range of nail lengths and in many different materials. You set the air pressure at 70 psi for short nails in soft materials. You might have to set the pressure up to 120 psi some day to drive the maximum length nail it will drive into something really hard. I hardly ever go over 90psi - I usually leave my compressor there really. When I want to drive a shorter nail, I grab a smaller nailer (I now have a 23 gauge, an 18 gauge, and a 16 gauge). If you gun works well at 70 for what you are doing, great, but I suspect you may want to use a bit higher pressure. All my nailers will drive their longest nails into hardwood at 90 psi (except for the HF stapler I commented on above).
