Forum Name
  • alpha
    • 352
    • Owensboro, KY, USA.
    Forum Name
    I suggest the forum name "Classified Advertisements" be changed to "Classifieds". There are some "Popup Blockers" that reject the word "advertisement" and closes the window for the BT site. I have run into this problem while experimenting with IE and a new version of System Mechanic. Just a suggestion.
  • Sam Conder
    Woodworker Once More
    • 2502
    • Midway, KY
    • Delta 36-725T2
    I strongly dislike software that pulls "willy-nilly" stunts like this. I've already had to change the name of the Support ASP page because Norton was blocking it. Oh well...
    Sam Conder
    BT3Central's First Member
    • mudder
      • 1532
      • I live in a house
      • Delta 36-650
      Does System mechanic have a "white list" of sites that are acceptable? You should investigate that. I agree with Sam, A popup blocker should do just that. Reject popups and not the sites you want to go to.
      Just my opinion.
      Mudder
      • alpha
        • 352
        Yes. It does have a list...but the list is based on words and not a site. I didn't see any way to exempt any one site. I guess that limits the usefullness of the program. Of course you could disable the program or eliminate the word "advertisement" to work around. Otherwise, Sysem Mechanic is a great little program. I've been using it for years. Here is a link for a free trial: http://www.iolo.com/
        It does a lot of the things Norton Utilities does, only faster and not quite a comprehensive.
        Thanks Sam, for the quick change.
