How do I post icons? I cannot get them to appear in the body of a message. When I click on one it always ends up in the "title" area.
Icon question
Tags: None
The icons at the bottom are for titles. The Smilies at the right are for the body of the message. Also, when you're posting a message, make sure you don't have "Disable smilies in text" checked, down in the Additional Options area below the box in which you compose your message.
If you don't see the Smilies at all, over on the right, go to your User Control Panel, select Edit Options, scroll down to the bottom, and for your Message Editor Interface select either Standard or Enhanced. With Basic selected, you don't get the smilies. Be sure to hit "Save Changes" when you're finished.Last edited by LarryG; 10-02-2008, 11:40 AM.Larry -
Use the smiley's that are located on the right side of the new post page. Clicking one of them will put the vbcode into the post. That code is what will produce the smileys once you submit the post. You'll also see them if you preview your post too.
The post icons on the bottom are just icons and do only what you've seen them do.ErikComment
