Did the message limit for PM's change with the upgrade? Or is it just me!
Pm Message Limit?
Pm Message Limit?
Tags: None -
Size of the message or number of message you are allowed to have?Sam Conder
BT3Central's First Member
"I have not failed. I've just found 10,000 ways that won't work." -Thomas A. Edison -
Number. All I see is a red bar which says I have two messages out of a total of 0 allowed.Donate to my Tour de Cure
Odd. Mine says it has 37 of 50 allowed. The 50 hasn't changed since the upgrade. Reminds me I need to clean out some of those messages though.David
Mea culpa. Try now.Sam Conder
"I have not failed. I've just found 10,000 ways that won't work." -Thomas A. EdisonComment
Mine says
0 New PMs. You have 18 total out of 50 allowed.
I'm 99 44/100% sure that is what it was before the change. Sounds like the problems is with Black walnut's account, not across the board.Ric
Plan for the worst, hope for the best!Comment
Whatever you did fixed it Sam, Thanks.Donate to my Tour de Cure
