For those with Safari Browser
  • Sam Conder
    Woodworker Once More
    • 2502
    • Midway, KY
    • Delta 36-725T2
    Could you tell me if things are better now?
    Thanks in advance,
    Sam Conder
    BT3Central's First Member
  • ElRay
    • 367
    • NoIL
    Don't know if the renderring is better in Safari (I use iCab), but there's still HTML errors. Nothing stands out as an obvious render-error trigger, except maybe the missing cell start tags. This is most often caused by crossed-tags, eg ...<td><font> ... </td></font> or things like <div>'s put inside of cells or other tags that they shouldn't be.
    Sorry, this is a peccadillo of mine. Let me know if you want some help.
    Ray
    http://www.bt3central.com/forum/topic.asp?TOPIC_ID=7261
    Altogether 239 errors found. Only 100 errors are listed below.
    Error (76/5): In the tag <TD> the attribute "BORDER" is not allowed.
    Warning (89/2): In the tag <TD> the value of the attribute "WIDTH" must be enclosed in quotes.
    Warning (92/2): In the tag <TD> the value of the attribute "WIDTH" must be enclosed in quotes.
    Error (96/3): The character '&' must be written as '&'.
    Error (97/3): The character '&' must be written as '&'.
    Warning (102/2): In the tag <TD> the value of the attribute "WIDTH" must be enclosed in quotes.
    Warning (105/2): In the tag <TD> the value of the attribute "WIDTH" must be enclosed in quotes.
    Error (108/6): The start tag for </TD> can't be found.
    Error (109/3): The start tag for </TR> can't be found.
    Error (112/1): <LINK> is only allowed in the head of the file.
    Warning (125/2): The attribute "COLOR" is not allowed for the tag <HR>.
    Warning (130/97): In the tag <IMG> the value of the attribute "SRC" must be enclosed in quotes.
    Error (130/97): In tag <IMG> the value "center" is not valid for attribute "ALIGN".
    Warning (132/2): The attribute "COLOR" is not allowed for the tag <HR>.
    Error (142/34): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (142/70): Invalid characters in tag or attributes.
    Error (142/70): The attribute "/" is not part of HTML.
    Warning (146/43): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (149/30): The tag <FONT> should no longer be used since HTML 4.0.
    Error (150/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (152/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (154/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (156/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (158/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (160/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (162/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (164/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (166/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (168/11): Only digits are allowed in the value of the attribute "TABINDEX".
    Warning (176/36): The tag <FONT> should no longer be used since HTML 4.0.
    Error (176/104): Invalid characters in tag or attributes.
    Error (176/104): The attribute "/" is not part of HTML.
    Error (177/21): Only digits are allowed in the value of the attribute "TABINDEX".
    Error (182/9): The start tag for </FORM> can't be found.
    Warning (217/47): The tag <FONT> should no longer be used since HTML 4.0.
    Error (218/11): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (218/11): Invalid characters in tag or attributes.
    Error (218/11): The attribute "/" is not part of HTML.
    Error (218/155): Invalid characters in tag or attributes.
    Error (218/155): The attribute "/" is not part of HTML.
    Error (219/11): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (219/11): Invalid characters in tag or attributes.
    Error (219/11): The attribute "/" is not part of HTML.
    Error (219/105): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (219/105): Invalid characters in tag or attributes.
    Error (219/105): The attribute "/" is not part of HTML.
    Error (219/259): Invalid characters in tag or attributes.
    Error (219/259): The attribute "/" is not part of HTML.
    Error (220/11): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (220/11): Invalid characters in tag or attributes.
    Error (220/11): The attribute "/" is not part of HTML.
    Error (220/107): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (220/107): Invalid characters in tag or attributes.
    Error (220/107): The attribute "/" is not part of HTML.
    Error (220/201): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (220/201): Invalid characters in tag or attributes.
    Error (220/201): The attribute "/" is not part of HTML.
    Error (220/383): Invalid characters in tag or attributes.
    Error (220/383): The attribute "/" is not part of HTML.
    Error (221/11): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (221/11): Invalid characters in tag or attributes.
    Error (221/11): The attribute "/" is not part of HTML.
    Error (221/107): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (221/107): Invalid characters in tag or attributes.
    Error (221/107): The attribute "/" is not part of HTML.
    Error (221/203): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (221/203): Invalid characters in tag or attributes.
    Error (221/203): The attribute "/" is not part of HTML.
    Error (221/297): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (221/297): Invalid characters in tag or attributes.
    Error (221/297): The attribute "/" is not part of HTML.
    Warning (223/11): The tag <FONT> should no longer be used since HTML 4.0.
    Error (224/11): The character '&' must be written as '&'.
    Error (224/54): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (224/54): Invalid characters in tag or attributes.
    Error (224/54): The attribute "/" is not part of HTML.
    Error (224/171): The character '&' must be written as '&'.
    Error (225/7): The character '&' must be written as '&'.
    Error (225/67): The character '&' must be written as '&'.
    Error (225/129): Invalid characters in tag or attributes.
    Error (225/129): The attribute "/" is not part of HTML.
    Error (226/11): The character '&' must be written as '&'.
    Error (226/68): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (226/68): Invalid characters in tag or attributes.
    Error (226/68): The attribute "/" is not part of HTML.
    Error (226/180): The character '&' must be written as '&'.
    Error (227/11): Invalid characters in tag or attributes.
    Error (227/11): The attribute "/" is not part of HTML.
    Error (227/17): The character '&' must be written as '&'.
    Error (227/145): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (227/145): Invalid characters in tag or attributes.
    Error (227/145): The attribute "/" is not part of HTML.
    Error (227/415): The character '&' must be written as '&'.
    Warning (227/657): The tag <FONT> should no longer be used since HTML 4.0.
    Error (228/135): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (228/135): Invalid characters in tag or attributes.
    Error (228/135): The attribute "/" is not part of HTML.
    Error (229/11): Invalid characters in tag or attributes.
    Error (229/11): The attribute "/" is not part of HTML.
    Error (229/92): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
    Error (229/92): Invalid characters in tag or attributes.
    Warning (244/76): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (245/70): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (246/121): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (247/60): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (251/20): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (254/17): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (255/17): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (256/17): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (257/23): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (258/17): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (260/19): The attribute "HEIGHT" is not allowed for the tag <TABLE>.
    Warning (263/115): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (275/44): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (276/23): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (280/64): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (286/76): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (287/70): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (288/121): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (289/60): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (304/11): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (308/657): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (315/11): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (367/71): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (370/73): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (374/47): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (382/52): The attribute "WRAP" is not allowed for the tag <TEXTAREA>.
    Warning (385/73): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (401/66): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (402/67): The tag <FONT> should no longer be used since HTML 4.0.
    Warning (411/23): The tag <FONT> should no longer be used since HTML 4.0.
    "A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects."
    --- Robert A. Heinlein
      • 8793
      Sam,
      You did it! You did it!
      It works fine now in mine.
      By the way, could you possibly tell me what was the problem, in case I run into this on other sites?
      THANKS!
      • Sam Conder
        • 2502
        • Midway, KY
        • Delta 36-725T2
        Well, it was webauthor error, sorta. Without getting too deep into the syntax of HTML, which would no doubt expose how little I actually know, the <TD> tags were "hosed up". This was caused by the way Snitz renders some common code I use to keet the look and feel of the site consistent. Basically, I have 3 "template files" called include files that make up the top header, the left side menu, and the bottom footer. These templates are 3 single files that I can edit once and it changes it throughout the entire site. When the includes gos stuck into the forum, it messed up the <TD> tags and caused everything to go haywire. I had to do a little creative editing to strip out the <TD> tags.
        Sam Conder
        • BillW
          • 176
          • Grapevine, TX, USA.
          Speakin' of which, how many of us are Mac users? I just switched in December myself. How about if you use an Apple you raise your hand.
          That's just my opinion, I could be wrong,
          ~Bill
          I'd give my left arm to be ambidextrous!
          • Sam Conder
            • 2502
            • Midway, KY
            • Delta 36-725T2
            (Psst.. Mac users, it's the thing on the end of your arm.)
            Sam Conder
            • milanuk
              • 287
              • Wenatchee, WA, USA.
              Sam, Sam, Sam... Low. Very low
              I still Windows... at work... under protest I think of myself more as a *nix user... Linux & BSD, then moved to Macs w/ OS X so the rest of the family could actually use the computer
              Monte
              All right, breaks over. Back on your heads!
              • Eric
                • Jun 2003
                • 653
                • Cocolalla, ID
                • Grizzly G0691 & BT3100
                Sam,
                [:0][:I][^]
                • Raffi
                  • 198
                  • CA, USA.
                  Much better Sam. Not bad for a PC user.
                  Raffi
                  • Raffi
                    • 198
                    • CA, USA.
                    Raffi
                    • Sam Conder
                      • 2502
                      • Midway, KY
                      • Delta 36-725T2
                      Hey Raffi, you only have to tell a PC user once...
                      Sam Conder
                      • Lefty
                        • 874
                        • Sioux Falls, SD, USA.
                        That's the ticket, Sam! Good work!
                        (that's me raising my hand as a Mac guy).
                        Semper Mac!
                        I know Bruce Cohen is one of us, too.
                        one of us... one of us... one of us...
                        Eric
                        -Supplier of quality sawdust to southeast South Dakota!
                        • Lefty
                          • 874
                          New Poll:
                          Are you a Mac user?
                          Eric
