I know the forums are a canned package, so I don't know how much control Sam has over this, but the HTML that's returned is loaded with errors. See the error report below. If everything is template based, I'd be willing to help-out and clean-up the HTML.
Ray
http://www.bt3central.com/forum/default.asp
Altogether 408 errors found. Only 100 errors are listed below.
Warning (1/1): <!DOCTYPE> is missing.
Warning (69/1): The attribute "LEFTMARGIN" is not allowed for the tag <BODY>.
Warning (69/1): The attribute "TOPMARGIN" is not allowed for the tag <BODY>.
Error (69/1): The attribute "rightmargin" is not part of HTML.
Error (69/1): The attribute "bottommargin" is not part of HTML.
Error (69/1): In the tag <BODY> the attribute "MARGINWIDTH" is not allowed.
Error (69/1): In the tag <BODY> the attribute "MARGINHEIGHT" is not allowed.
Warning (69/1): The color name "midnightblue" is not part of the HTML standard.
Warning (69/1): The color name "darkblue" is not part of the HTML standard.
Warning (70/19): The tag <FONT> should no longer be used since HTML 4.0.
Error (73/5): In the tag <TD> the attribute "BORDER" is not allowed.
Error (85/1): <LINK> is only allowed in the head of the file.
Warning (88/2): In the tag <TD> the value of the attribute "WIDTH" must be enclosed in quotes.
Warning (88/2): In the tag <TD> the attribute "WIDTH" should only contain absolute pixel values.
Warning (91/2): In the tag <TD> the value of the attribute "WIDTH" must be enclosed in quotes.
Warning (91/2): In the tag <TD> the attribute "WIDTH" should only contain absolute pixel values.
Error (92/3): The character '&' must be written as '&'.
Warning (101/2): In the tag <TD> the value of the attribute "WIDTH" must be enclosed in quotes.
Warning (101/2): In the tag <TD> the attribute "WIDTH" should only contain absolute pixel values.
Warning (104/2): In the tag <TD> the value of the attribute "WIDTH" must be enclosed in quotes.
Warning (104/2): In the tag <TD> the attribute "WIDTH" should only contain absolute pixel values.
Error (107/6): The start tag for </TD> can't be found.
Error (108/3): The start tag for </TR> can't be found.
Error (111/1): <LINK> is only allowed in the head of the file.
Warning (116/193): The attribute "NAME" is not allowed for the tag <IMG>.
Warning (117/183): The attribute "NAME" is not allowed for the tag <IMG>.
Warning (118/178): The attribute "NAME" is not allowed for the tag <IMG>.
Warning (119/182): The attribute "NAME" is not allowed for the tag <IMG>.
Warning (120/202): The attribute "NAME" is not allowed for the tag <IMG>.
Warning (121/197): The attribute "NAME" is not allowed for the tag <IMG>.
Warning (122/212): The attribute "NAME" is not allowed for the tag <IMG>.
Warning (125/2): The attribute "COLOR" is not allowed for the tag <HR>.
Warning (128/19): In the tag <IMG> the value of the attribute "SRC" must be enclosed in quotes.
Error (128/19): In tag <IMG> the value "center" is not valid for attribute "ALIGN".
Warning (132/11): The attribute "COLOR" is not allowed for the tag <HR>.
Error (136/11): The start tag for </TD> can't be found.
Warning (141/5): In the tag <TD> the attribute "WIDTH" should only contain absolute pixel values.
Error (141/34): Only digits are allowed in the value of the attribute "TABINDEX".
Error (141/70): Invalid characters in tag or attributes.
Error (141/70): The attribute "/" is not part of HTML.
Warning (142/5): In the tag <TD> the attribute "WIDTH" should only contain absolute pixel values.
Warning (145/30): The tag <FONT> should no longer be used since HTML 4.0.
Warning (148/30): The tag <FONT> should no longer be used since HTML 4.0.
Error (149/11): Only digits are allowed in the value of the attribute "TABINDEX".
Error (151/11): Only digits are allowed in the value of the attribute "TABINDEX".
Error (153/11): Only digits are allowed in the value of the attribute "TABINDEX".
Error (155/11): Only digits are allowed in the value of the attribute "TABINDEX".
Error (157/11): Only digits are allowed in the value of the attribute "TABINDEX".
Error (159/11): Only digits are allowed in the value of the attribute "TABINDEX".
Error (161/11): Only digits are allowed in the value of the attribute "TABINDEX".
Error (163/11): Only digits are allowed in the value of the attribute "TABINDEX".
Error (165/11): Only digits are allowed in the value of the attribute "TABINDEX".
Error (167/11): Only digits are allowed in the value of the attribute "TABINDEX".
Warning (169/9): The attribute "NAME" is not allowed for the tag <FORM>.
Warning (175/36): The tag <FONT> should no longer be used since HTML 4.0.
Error (175/104): Invalid characters in tag or attributes.
Error (175/104): The attribute "/" is not part of HTML.
Error (176/21): Only digits are allowed in the value of the attribute "TABINDEX".
Error (181/9): The start tag for </FORM> can't be found.
Error (207/17): The color name "CCCCCC" is not valid.
Warning (207/76): The tag <FONT> should no longer be used since HTML 4.0.
Error (208/17): The color name "CCCCCC" is not valid.
Warning (208/76): The tag <FONT> should no longer be used since HTML 4.0.
Error (209/17): The color name "CCCCCC" is not valid.
Warning (209/76): The tag <FONT> should no longer be used since HTML 4.0.
Error (210/17): The color name "CCCCCC" is not valid.
Warning (210/76): The tag <FONT> should no longer be used since HTML 4.0.
Error (211/17): The color name "CCCCCC" is not valid.
Warning (211/76): The tag <FONT> should no longer be used since HTML 4.0.
Error (212/17): The color name "CCCCCC" is not valid.
Warning (212/76): The tag <FONT> should no longer be used since HTML 4.0.
Error (213/17): The color name "CCCCCC" is not valid.
Error (216/17): The color name "990000" is not valid.
Error (216/110): Invalid characters in tag or attributes.
Error (216/110): The attribute "/" is not part of HTML.
Warning (216/317): The tag <FONT> should no longer be used since HTML 4.0.
Error (216/317): The color name "FFFF99" is not valid.
Error (217/17): The color name "990000" is not valid.
Warning (217/76): The tag <FONT> should no longer be used since HTML 4.0.
Warning (220/17): The color name "whitesmoke" is not part of the HTML standard.
Error (220/136): Invalid characters in tag or attributes.
Error (220/136): The attribute "/" is not part of HTML.
Warning (221/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (221/67): The tag <FONT> should no longer be used since HTML 4.0.
Warning (221/67): The color name "midnightblue" is not part of the HTML standard.
Error (221/283): Invalid characters in tag or attributes.
Error (221/283): The attribute "/" is not part of HTML.
Warning (221/289): The tag <FONT> should no longer be used since HTML 4.0.
Warning (222/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (222/68): The tag <FONT> should no longer be used since HTML 4.0.
Warning (222/68): The color name "midnightblue" is not part of the HTML standard.
Warning (223/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (226/17): The color name "whitesmoke" is not part of the HTML standard.
Error (226/131): Invalid characters in tag or attributes.
Error (226/131): The attribute "/" is not part of HTML.
Warning (227/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (227/67): The tag <FONT> should no longer be used since HTML 4.0.
Warning (227/67): The color name "midnightblue" is not part of the HTML standard.
Error (227/274): Invalid characters in tag or attributes.
Error (227/274): The attribute "/" is not part of HTML.
Warning (227/280): The tag <FONT> should no longer be used since HTML 4.0.
Warning (228/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (228/68): The tag <FONT> should no longer be used since HTML 4.0.
Warning (228/68): The color name "midnightblue" is not part of the HTML standard.
Warning (229/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (232/17): The color name "whitesmoke" is not part of the HTML standard.
Error (232/136): Invalid characters in tag or attributes.
Error (232/136): The attribute "/" is not part of HTML.
Warning (233/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (233/67): The tag <FONT> should no longer be used since HTML 4.0.
Warning (233/67): The color name "midnightblue" is not part of the HTML standard.
Error (233/254): Invalid characters in tag or attributes.
Error (233/254): The attribute "/" is not part of HTML.
Warning (233/260): The tag <FONT> should no longer be used since HTML 4.0.
Warning (234/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (234/68): The tag <FONT> should no longer be used since HTML 4.0.
Warning (234/68): The color name "midnightblue" is not part of the HTML standard.
Warning (235/17): The color name "whitesmoke" is not part of the HTML standard.
Error (238/17): The color name "990000" is not valid.
Error (238/110): Invalid characters in tag or attributes.
Error (238/110): The attribute "/" is not part of HTML.
Warning (238/317): The tag <FONT> should no longer be used since HTML 4.0.
Error (238/317): The color name "FFFF99" is not valid.
Error (239/17): The color name "990000" is not valid.
Warning (239/76): The tag <FONT> should no longer be used since HTML 4.0.
Warning (242/17): The color name "whitesmoke" is not part of the HTML standard.
Error (242/127): Invalid characters in tag or attributes.
Error (242/127): The attribute "/" is not part of HTML.
Warning (243/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (243/67): The tag <FONT> should no longer be used since HTML 4.0.
Warning (243/67): The color name "midnightblue" is not part of the HTML standard.
Error (243/245): Invalid characters in tag or attributes.
Error (243/245): The attribute "/" is not part of HTML.
Warning (243/251): The tag <FONT> should no longer be used since HTML 4.0.
Warning (244/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (244/68): The tag <FONT> should no longer be used since HTML 4.0.
Warning (244/68): The color name "midnightblue" is not part of the HTML standard.
Warning (245/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (248/17): The color name "whitesmoke" is not part of the HTML standard.
Error (248/102): Invalid characters in tag or attributes.
Error (248/102): The attribute "/" is not part of HTML.
Warning (249/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (249/55): The tag <FONT> should no longer be used since HTML 4.0.
Warning (249/55): The color name "midnightblue" is not part of the HTML standard.
Error (249/203): Invalid characters in tag or attributes.
Error (249/203): The attribute "/" is not part of HTML.
Warning (249/209): The tag <FONT> should no longer be used since HTML 4.0.
Warning (250/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (250/70): The tag <FONT> should no longer be used since HTML 4.0.
Warning (250/70): The color name "midnightblue" is not part of the HTML standard.
Warning (251/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (251/70): The tag <FONT> should no longer be used since HTML 4.0.
Warning (251/70): The color name "midnightblue" is not part of the HTML standard.
Warning (252/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (252/77): The tag <FONT> should no longer be used since HTML 4.0.
Warning (252/77): The color name "midnightblue" is not part of the HTML standard.
Error (252/163): Invalid characters in tag or attributes.
Error (252/163): The attribute "/" is not part of HTML.
Error (252/178): Invalid characters in tag or attributes.
Error (252/178): The attribute "/" is not part of HTML.
Error (252/222): The character '&' must be written as '&'.
Error (252/444): The character '&' must be written as '&'.
Error (252/506): In tag <IMG> the value "absmiddle" is not valid for attribute "ALIGN".
Error (252/506): Invalid characters in tag or attributes.
Error (252/506): The attribute "/" is not part of HTML.
Warning (253/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (253/68): The tag <FONT> should no longer be used since HTML 4.0.
Warning (253/68): The color name "midnightblue" is not part of the HTML standard.
Error (253/166): The tag <NOBR> is an extension by Netscape but not part of the official HTML standard.
Error (253/172): The character '&' must be written as '&'.
Error (253/378): The tag <NOBR> is an extension by Netscape but not part of the official HTML standard.
Error (253/384): The character '&' must be written as '&'.
Error (253/594): The tag <NOBR> is an extension by Netscape but not part of the official HTML standard.
Error (253/600): The character '&' must be written as '&'.
Error (253/809): The tag <NOBR> is an extension by Netscape but not part of the official HTML standard.
Error (253/815): The character '&' must be written as '&'.
Warning (254/17): The color name "whitesmoke" is not part of the HTML standard.
Error (254/77): The character '&' must be written as '&'.
Error (254/121): Invalid characters in tag or attributes.
Error (254/121): The attribute "/" is not part of HTML.
Error (254/249): The character '&' must be written as '&'.
Error (254/294): Invalid characters in tag or attributes.
Error (254/294): The attribute "/" is not part of HTML.
Warning (257/17): The color name "whitesmoke" is not part of the HTML standard.
Error (257/101): Invalid characters in tag or attributes.
Error (257/101): The attribute "/" is not part of HTML.
Warning (258/17): The color name "whitesmoke" is not part of the HTML standard.
Warning (258/55): The tag <FONT> should no longer be used since HTML 4.0.
Warning (258/55): The color name "midnightblue" is not part of the HTML standard.
Error (258/203): Invalid characters in tag or attributes.
Error (258/203): The attribute "/" is not part of HTML.
Warning (258/209): The tag <FONT> should no longer be used since HTML 4.0.
Warning (259/17): The color name "whitesmoke" is not part of the HTML standard.
Error (261/163): Invalid characters in tag or attributes.
Error (261/163): The attribute "/" is not part of HTML.
Error (261/178): Invalid characters in tag or attributes.
Error (261/178): The attribute "/" is not part of HTML.
Error (261/222): The character '&' must be written as '&'.
Error (261/437): The character '&' must be written as '&'.
"A human being should be able to change a diaper, plan an invasion,
butcher a hog, conn a ship, design a building, write a sonnet,
balance accounts, build a wall, set a bone, comfort the dying, take
orders, give orders, cooperate, act alone, solve equations, analyze
a new problem, pitch manure, program a computer, cook a tasty meal,
fight efficiently, die gallantly. Specialization is for insects."
--- Robert A. Heinlein
Ray
