Pic Test
  • Crockett
    • 253
    • Buffalo, NY, USA.
    Pic Test
    Al
  • Crockett
    • 253
    • Buffalo, NY, USA.
    Al
    • Archania
      • 69
      • Bethlehem, PA
      Nope and Nope...
        Keep testing!
        Don, aka Pappy, aka SicPup
        I don't suffer from insanity, I enjoy it!
          • 8803
          quote:Originally posted by Crockett
          Crockett,
          The problem is that on your image, you need to right(?) click hold on the image you wish to post (from/on Imagestation). You will see "copy image location" - and that image location URL/Link should end in ".jpg" - not .jpg.orig.jpg or something similar.
          Paste that link [ img ] [u]here</u> [ /img ] , which you did on your second post. (my [ img ] has spaces in it to keep it from activating nothing).
          The link you used was: http://www.imagestation.com/album/?id=4290519375&idx=9
          Which does not end in .jpg. So just keep trying until your find one that ends that way.
          UPDATING THIS POST:
          Crockett, here is the correct URL:
          http://www.imagestation.com/picture/...7/fc447993.jpg
          Since you are testing, I will let you play with the picture on Imagestation until you find this specific URL. Then post that like you did in the second post.
          Hank
            Crockett, all I could see was the red X so I didn't know you were trying to post from Imagestation.
            Open your album to the picture you want to post and left click on the picture. That will open a second window with the picture. Copy that URL and paste it as Hank showed. Then delete the .orig.jpg at the end of the URL.
            I just tried Hank's suggestion of right click / copy short cut. Comes up with the same URL as my method, but easier.
              • 8803
              Pappy, There is a trick to this, and kinda simple: Instead of answering in the box at the bottom of all the posts, I simply went to the "Reply with a quote" icon and clicked on it. It gave me the link that he used.
              In all honesty, I had trouble with figuring out "Size and color" of fonts as well as posting that "one underlined word" that was actually the hyperlink that several people used. I just clicked on "Reply with Quote" and copied what others had done! After two or three tries, I finally "learned" the system.
              Hank
              • Crockett
                • 253
                • Buffalo, NY, USA.
                Ok Guys thanks for the help, for some reason I couldn't remember how I did this the first time I posted I pic!
                Al
                  • 8803
                  I meant to comment on the great looking rack when I posted above, but I wanted to wait until you did it.
                  Hank
