No more automatic log-on?
  • kwerner
    • 9
    • Norwalk, CT, USA.
    I've just returned after a couple of weeks travelling and the world has turned beneath me again! Is it true that with the switch to BT3Central.com we've lost automatic log-on, or am I doing something wrong?
    BTW, is it my imagination or has the spirit here really become even better than it was/is on the Ryobi forum?
    Ken
    Auto log on is there. But the site was off-line for a few hours a couple of weeks ago while Sam changed the site to BT3Central. If this is your first time since that re-construction, then you will may have to re-do your log on; but should be just a one time thing.
    Hank
    • RodKirby
      • 3136
      • Mao Shan TSC-10RAS
      Ken
      I'm glad it wasn't just me that felt that way. Welcome back
      A Professional is someone who does what they say they will do.
      Downunder ... 1" = 25.4mm
      • Ikeb
        • 147
        • Ottawa, Ontario, Canada.
        It is[?] How does one turn it on then[?]
        Ike
        You can never have enough clamps
        • Stytooner
          Roll Tide RIP Lee
          • 4301
          • Robertsdale, AL, USA.
          You need to accept the forum cookies for it to work.
          http://www.leestyron.com
          • Ikeb
            • 147
            According to the Forum FAQ Cookie section:
            quote:These Forums use cookies to store the following information: the last time you logged in, your Username and your Encrypted Password. These cookies are stored on your hard drive. Cookies are not used to track your movement or perform any function other than to enhance your use of these forums. [u]If you have not enabled cookies in your browser, many of these time-saving features will not work properly. Also, you need to have cookies enabled if you want to enter a private forum or post a topic/reply</u>.
            You may delete all cookies set by these forums in selecting the "logout" button at the top of any page.
            Note the underlined text. Since I am able to use all features mentioned and can post a topic/reply I must have cookies enabled. I know cookies are enabled for other sites I visit and I don't, to my knowledge, have any mechanisms installed to defeat cookies on a per site basis.
            I don't quite understand the last paragraph/sentence though. I take it that when I click the Logout button (i.e once I'm leaving the site) all cookies are deleted. So each session generates new cookies? How can a password be remembered then ... and for that matter how can auto-login possibly work?
            Ike
              There are two parts to the memory/cookies/preferences. One part is stored on the BT3Central server and one on your computer. Your computer has the cookies that lets this site know that it is you. A second part is on this server remembering who you are when you come to this web site, provided your password is given - and that is done by either the cookie, or by you typing the password and user name at log in. Logging out does cut the cookies which tell this site who you are.
              A second part is this: if you enable your cookies (and you have), and you leave this site without "logging out" - the next time you come back, your cookies and this site know each other, and you will be "automatically" logged on. However, you must tell this site to "remember" your password and you must leave without logging out.
              Hank
              • kwerner
                • 9
                • Norwalk, CT, USA.
                Thank you, gentlemen. In addition to having to log on after the domain change, I hadn't realized that I should NOT log out.
                Ken
                  Ken,
                  One more thing about "logging out" - it is a safety feature for those whose computers are used "occasionally" and especially "often" by other people. For instance, if someone clicks on this site from your computer while "auto log on" is in effect, they will be logged on as "you" automatically and can post anything and even edit any of your posts.
                  If no one else uses your computer, or if you have to "give a password" everytime you use your computer, then you should be safe.
                  Hank
                  • Ikeb
                    • 147
                    Thanks for the additional info Hank. I was about to ask you why the logout button behaves that way.
                    I take it that the logout is an activity timeout. What is the inactivity period that signals an auto-logout? I'm guessing that's important from a site administration perspective as well as slightly skewing the "Who's online" info. But the inactivity timer also triggers marking folders as read. From the user's perspective, other than the folder colour change, there is no logout and thus no login -- the cookie takes care of the latter.
                    Suggestion: Demote the prominent position of the current Logout button to reduce accidental use. I've occassionally clicked the button when I really intended to post a message. [:I]
                    Ike
                    • AttilatheHun
                      • 831
                      • Farnham, Surrey, United Kingdom.
                      I have been logged on for some 800 minutes on one occasion, with no post for around 6 hours (at night). Never got logged off. I don't think there is an inactivity timer.
                      AtH
                      This looks complicated, better get a bigger hammer
                      • Ikeb
                        • 147
                        How then do folders get marked as "read"?
                        And how come you disappear as an "Active User"?
                        Ike
