I liked it on sight - simple, (relatively) easy to make and IT WORKS very effectively.
I used DIY 1/4" studded knobs (a bolt captured in a 2 part soft-touch Knob). The article used 5/16" - IMHO over-engineered. I chose t-nuts instead of brass inserts. It all grips very securely.
Edit: The arm segments are 7" long x 2" wide
On the scoop - the hardest thing I've ever had to make! Tapers, bevels, rabbets - 2 days work, with LOTS of think time. 2 screws joining the tab, otherwise all glued.
All finished in wipe-on poly
BTW - Not obvious, but the base is just clamped wherever you need it - in this case; to the DP table.
I'll leave it to you guys to think about all the applications this thing has...
My first thought looking at the 1st picture was "you have got to be kidding" . By the 3rd I was think, "I got to build me one of those"
Thanks for the inspiration.
Bob
Oh what a tangled web we weave, when we are all hopped up on caffine.
I knew it was rod from the image before I saw the name. Yeah, his jigs are quite spectacular. That would indeed be darned useful, can hook the shop-vac or the DC to it. Very nice. I think I might make one for my DP.
But I am confused: After having seen so many photos from Rod's shop, I was convinced australian wood products cut dust free...
Remember, he's Down Under, on the bottom side of the world. If he ever pointed his camera UP, at the ceiling, I'm sure we'd see a layer of MDF dust a good 6" deep ...
