Need to be Cool
  • bigstick509
    • 1227
    • Macomb, MI, USA.
    Need to be Cool
    Well, the temp. got up to the low 80's today,and the the shop was a little uncomfortable. How do most of the members cool there shops?
    The shop{garage} is in the northeast corner of the house so it is not in the sun all day, my initial thought was maybe a ceiling fan but recycling the air with micro sawdust might not be a good idea. My only other idea short of air conditioning was a couple of box fans, one inbound and one exhaust. Any suggestions?
  • JeffW
    • 1594
    • San Antonio, Texas, USA.
    When it gets over a 100, I just go in and out alot.
    Measure twice, cut once, screw it up, start over
      When it hits the low 80's in Texas, we grab a light jacket![]
      • Jim Boyd
        • 1766
        • Montgomery, Texas, USA.
        • Delta Unisaw
        Geeze Pappy, let me get my waders on before you start filling the room up with that $%^&! Everybody knows any self-respecting Texan just turns on the A/C
        • Ken Weaver
          • 2417
          • Clemson, SC, USA
          • Rigid TS3650
          I open the <s>garage</s>, err shop doors and turn on a window fan.
          Ken Weaver
          Clemson, SC
          • Stick
            • 872
            • Grand Rapids, MB, Canada.
            Well, 80's about as hot as we ever see up here. My shops are insulated so well for our winters (12" walls, 24" ceiling, 4" thick doors, only one 2' square triple pane window in each one), that I have to leave doors open or build a fire to get them WARM enough to work comfortably when it's 80 out. They stay about 45-50 if they're closed up. When it's -40°F in winter, the shops stay about +25°F without any heat. A wood fire gets it up to 80-90 within an hour. I wish my house was that well insulated! Previous owner was a cabinet maker that worked from home and he insulated the shops so that he could work all winter out there. So...my answer would have to be insulation, and lots of it!
            • monte
              ***** Windbag
              • 5242
              • Paw Paw, MI, USA.
              • GI 50-185M
              I usually open the windows and have a fan running in one of them. If it gets too hot I turn the A/C on.
              Monte (another darksider)
              • rbfunk
                • 400
                • Garfield, NJ, USA.
                My shop was originaly a garage with one double hung window on the east side. The overhead door faces south.
                Solution so far has been to open the window and the door. El-cheapo fan to move the air from the back and out the overhead door and what really cooled things down is a tarp rigged as an awning at the door. It keeps the sun from blasting in.
                The next step is to insulate, mostly for winter time but I hope it cuts down the heat gain.
                Bob
                Oh what a tangled web we weave, when we are all hopped up on caffine.
                  I use a couple of fans myself. They don't do much cooling but do stir the air so that it feels better.
                  • final_t
                    • 1626
                    Heat isn't the problem this weekend, humidity is. 77 now, "says" only 75% humidity. Supposed to hit 86 today.
                    • maxparot
                      • 1421
                      • Mesa, Arizona, USA.
                      • BT3100 w/ wide table kit
                      Out here in Arizona where it gets to be 120 during the summer I use multiple stages of cooling.
                      First is 2 ceiling fans. (If you have too much dust moving around because of the fans you don't have good enough dust control.)
                      Second stage is an evaporative cooler. (Swamp Cooler for those in the know) It can lower the temperature 20-25 degrees depending on the relative humidity. It becomes less effective as the humidity rises. Some folk report the moisture change effecting their wood but out here in Phoenix I haven't found it to be a problem. I may be due to the fact that when I use the Evap the outside air is extremely dry and as it becomes more humid (in monsoon season) I switch over to a 15000 BTU AirConditioner which is stage 3.
                      Opinions are like gas;
                      • Rounder
                        • 1287
                        • Sanford, FL, USA.
                        It is already in the 90's here and humid. Just a few minutes in the shop and you are soaking wet. I have double doors at the north end and a door on the west side. I do not have any windows that can be opened. The shop is not sealed enough to have a/c.
                        What I did was take a cheap box fan and build a 2 x 4 stand for it. I put it in front of the double doors. I have another fan mounted in the upper corner of the opposite side of the shop to help create a cross breeze.
                        George AKA Rounder
                        "Amarillo Slim, the greatist proposition gambler of all time held to his father's maxim; You can shear a sheep many times, but you can skin him only once."
                        • BobSch
                          • 4385
                          If you don't already have one, add a roof vent of two to give the hot air someplace to go. That and a floor stand fan and all the doors open works when it hits 90/90 up here.
                          And for all of you not of the northern persuasion, yeah, we get hot, humid weather up here. It's called road construction season.
                          Bob
                          • pierhogunn
                            • 1567
                            • Harrisburg, NC, USA.
                            A small AC unit, or one of the portable units might work for you, just make sure you can vent that heat outside somehow
                            Dan
                            Monty Python's Flying Circus
                            Dan in Harrisburg, NC
                            • sawdustman
                              • Jan 2005
                              • 49
                              • Pittsburgh, PA.
                              So true.
