Panel Cutting Table
  • bigstick509
    • 1227
    • Macomb, MI, USA.
    Panel Cutting Table
    I built this over the last couple of days to use in making my table saw out feed table. I can't believe how much easier this table makes things. I've been using a calapseable wallpaper table that I've had for years as a cutting-assembly table. This is well worth the 20.00 odd dollars that it took to make it.http://www.thewoodshop.20m.com/panel_cutting_table.htm
  • Popeye
    • 1848
    • Woodbine, Ga
    • Grizzly 1023SL
    Looks great Mike. I've been meaning to make a version of one for years. I've even got the leg set already. Nuther GATI project[B)] Pat
      Lay foam insulation board under the plywood and the table will last for years.
        Mine is built of 1x4s on edge on 1 foot centers. Dados at the intersections and glue hold it together. That keeps it light and keeps nails and/or screws away from the saw blade.
        • bigstick509
          • 1227
          • Macomb, MI, USA.
          Great suggestion Pappy, that would also help for light assembly and a universal place to expand my work surface sq. ft., it sure bets having to drag out a piece of sheet goods. Thanks
          • lcm1947
            • 1490
            • Austin, Texas
            • BT 3100-1
            Thanks for the thread Bigstick505. Love that table idea and the sites you directed us to. Excellent!
