Ok, I have assembled all the pieces parts for my router table.
M12V
Plywood
Switch/cord
Woodpecker Pluge Lift
Incra LS 17 super system
Laminate
However...in the time since I started collecting these items the shop (garage) has <s>shrunk</s> err, filled to capacity. I could probably squeeze in a dedicated table but it won't be easy.
I built a long BT3 mobile cabinet a while ago and it would be a great place to retrofit to accept the router (assuming I don't destroy it in the process).
It is constructed of 3/4" MDF with a formica top surface. My question (finally) is this...
If I install supports (cross braces) under the 3/4" MDF top, will it hold this router/lift or am I asking for sagging issues down the road?
TIA,
BobL.
M12V
Plywood
Switch/cord
Laminate
TIA,
BobL.
