Tenon on a dowel - neat tip...
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    http://www.woodworkingtips.com/etips/2005/04/01/wb/
    Downunder ... 1" = 25.4mm
  • monte
    ***** Windbag
    • 5242
    • Paw Paw, MI, USA.
    • GI 50-185M
    Nice idea!
    Monte (another darksider)
    • Mainemarc
      • 673
      • Portland, ME, USA.
      Angle the guide block a little closer to the fence as it runs off to the right and you'll get tapered tenons. Just the ticket for making new handles for vintage chisels if you don't have a lathe.
      Marc
      • dlminehart
        • 1829
        • San Jose, CA, USA.
        Yes, that sharp router bit does leave a neat tip . . .
        - David
        • DaveW
          • 415
          • So Cal.
          Wouldn't this leave a shoulder that isn't square? i.e., the transition between the tenon and the shoulder would be rounded with the radius of the straight bit?
          • RodKirby
            • 3136
            Good question.
            Having actually done this (using a 1" upcut spiral bit), I can say, make sure the bit is CENTERED under the dowell. Otherwise you will get the effect you describe.
