Last night at work (I'm a firefighter) we were sent to an industrial complex for a possible fire. There is a millwork company there and just outside their building they had 4 - 35 gallon garbage cans full of sawdust from their DC system. The contents of one of the cans was smoldering. We couldn't determine what it was but something had started a fire in the middle of the contents of the can and had burned a hole through the plastic wall of the garbage can.
Point to the story:
Check your shop smoke (or heat) detector, and make sure you have at least one fire extinguisher nearby. Also, be very careful with anything that may cause a fire.
These guys were lucky. The 4 garbage cans were located next to an overflowing dumpster, that had about 10 large wooden pallets leaning against it and 2 vans parked nearby.
Had it not been for the occupants of the building next store, things could have turned out worse.
I did mange to score a 3' x 3' piece of 1 1/4" laminated MDF from their scrap pile though!
Point to the story:
