Remotely-Operated Blast Gates -- How?
    My new shop will have its duct collection piping under the floor. For now it will be powered by my HF 2HP DC; in future, I plan to upgrade to a cyclone.
    For maximum efficiency, I want to locate the blast gates as close as possible to the main trunk, rather than at the end of each branch next to the machine it serves. This creates an accessibility problem: how do I open and close a blast gate that I can't get to?
    Two possible solutions that have already come to mind:
    1. Commercially-available motorized gates. These open and close automatically when a tool comes on and shuts off. Nice! Downside is high cost. Also, when I upgrade to a cyclone I will probably have larger ducts, and could end up stuck with some expensive motorized gates that are now too small.
    2. Cable-and-pulley system, operated by a lever or wheel located at each tool. I've given some thought to this and think it could be done reasonably easily. A little crude, maybe, but cheap and simple.
    My question is, is there another way? Would it be possible to cook up a home-brewed motorized solution, maybe using low-voltage DC motors or whatever?
    Maybe you could use some kind of wire-inside-spring actuation (kind of like an old-style manual choke cable with a knob on one end). Advantages: cheap hardware and standard blast gates, flexible routing, low maintenance.
    I would definitely shy away from putting anything that might need fixing under the floor...
    • thrytis
      • 552
      • Concord, NC, USA.
      • Delta Unisaw
      Check out this thread and this thread on a shop made pneumatic system. They may still not be cheap, but at least if you upgrade you should be able to reuse any of the expensive parts.
      Eric
      • master53yoda
        • Oct 2008
        • 456
        • Spokane Washington
        why don't you want them at the branch termination if the ducting is sealed it won't make a difference where they are located.
        just wondering.
        Art
          ... um, because I thought the body of experts known as "they" say the gates should be as close as possible to the main trunk, so that the DC unit will be sucking on as little empty pipe as possible when a gate is closed.
          Not true?
            Just thinking out loud here...
            How about using a lawn sprinkler controller? This allows a number of separate stations to activate. They now have models that have remote controls. These systems normally energize a spring-loaded electomagnet. The travel of the mechanism is insufficient for this application, but maybe something involving UC's spring mechanism could be rigged up.
            • toolguy1000
              • Mar 2009
              • 1142
              • westchester cnty, ny
              larry...funny, the body of experts known as "they" that i've encountered seemed to advocate keeping the blast gate as near to the individual tool as possible. but i see the reason for keeping it near the trunk, so seepage through unutilized branches doesn't compromise efficiency. have you checked the bill pentz site?
              http://billpentz.com/woodworking/cyclone/index.cfm
                I agree, it should be easily accessible.
                  I wonder if some sort of vacuum device could be adapted, like the ones that operate HVAC gates, hidden headlamps and such for cars. The DC itself should be able to create enough vacuum or develop enough for a vacuum reservoir.
                    So far I'm liking UC's choke cable idea best (which is not to say I don't appreciate the input from Eric, Art, JR, toolguy, and the other Erik ... thanks, guys).
                    McMaster-Carr -- which is not known for being the cheapest source, many times -- has push/pull cable assemblies with a 15'-8" long cable and a 5" maximum stroke for $32 each. Not dirt cheap, but less than a third of the ~$100 cost of a motorized gate (and I'd still need some way to control one of those). The 15'-8" should be a sufficiently long cable, and I'd probably spend a significant percentage of that $32 on any kind of shop-built mechanism. Hmm.
                    toolguy, Pentz is one of those who says to put the blast gates right off the main trunk.
                      Jeg's has a 6' choke cable for $6.99. http://www.jegs.com/i/JEGS/555/15830/10002/-1
                      • thrytis
                        • 552
                        • Concord, NC, USA.
                        • Delta Unisaw
                        Do you need a full 5" pull? With a little mechanical contraption on the gate, you could probably convert a shorter pull to 5" or 6" as necessary. Would that make the cable any cheaper?
                        Eric
                        • sweensdv
                          • 2873
                          • WI
                          • Baileigh TS-1040P-50
                          Larry, have you found this company yet in your researching, http://www.nordfab.com/index.cfm/do/pages.view/id/57/p/1/page/Nordfab-Products~Automatic-Blast-Gates ? Probably not the cheapest but on the surface it looks to me like you might be able to have the tool actually open and close the gate when it's powered on and off. Watch the video.
                            This guy's system is interesting.
                            http://videos.americanwoodworker.com...ust-Collection
                            • thrytis
                              • 552
                              • Concord, NC, USA.
                              • Delta Unisaw
                              Originally posted by JR
                              If you want to see additional details on that, see the links to ncwoodworker.net in my earlier post. That is the same guy.
                              Eric
