I'm trying to finalize the size of cabinets and countertops for a new shop. This is the approximate layout, except that I'm showing a cyclone DC when I will probably use a Delta two-bagger.
Space at the top right is for lumber storage. Space on the right directly opposite the doors is for 12 linear feet of cabinets and countertops. I will hang clamps...somewhere and I'm planning to install slatwall instead of pegboard for tool storage. One or perhaps two assembly/utility tables are also not shown.
At this stage, I'm thinking the 12' counter will be around 37" high, which is a bit shorter than our kitchen counters, and 24 inches deep. With a 4" toe kick and as much as 2 3/4" thickness for the countertops (I have a piece of butcher block I may use), that leaves me with about 28 1/2 inches of interior space for the drawers that will sit underneath (and support) the counter.
For the uppers, I'm thinking two 24inch wide by 24 inch deep by 54 inch tall cabinets at the ends and 8 feet of 18 inch deep by 24 inch tall cabinets in the middle The ceiling will be an odd height (91 3/4) to accommodate supports for the garage above so the bottom of the uppers in the middle would be at 5'7 which is fine for me.
That works out to 67 cubic feet of cabinets and 54 cubic feet of drawers.
I'm curious to know what others have done and what has and has not worked for you.
