Hello,
I'm looking for advice/feedback on what you have used for leveling permanently installed cabinets.
I've been working on a couple small cabinets based off of some of the ideas in Tom Clark's book; so far everything seems to be working out well. This fall/winter I have intentions (we'll see how far those get me...) of building some larger, longer workbench units along the walls. The small units I've done so far are mostly mobile, or small enough that level isn't much of an issue. For the bigger units, which span a longer distance on the concrete floor of my basement... I'm a little concerned that simply tacking furniture glides on the bottom won't cut it. Maybe they will; not sure I want to experiment on this one as fixing after the fact might be a bear.
I've seen a couple different setups... from making a tubafore base frame and shimming it level then permanently installing it and then setting the cabinet boxes on top, to using some hidden screw levelers to get things level and then tacking on base trim to cover any gaps. Any other options I should be aware of? Pros, cons, etc.?
TIA,
Monte
TIA,
Monte
The frame base from 3/4 ply sounds like a pretty decent way to go... give me a pseudo toe-kick area without having to deal w/ the irritation associated w/ 2x stock from the lumberyard twisting and warping.
