My shop is a 20'x20' cement block building with a basic shed roof that slopes down about 6" or so over its run from front to back.
The rafters are approximately 12' long 2x8 and overlap approx. 1/2 way. Under those rafters are a set of four 10' 2x8 sandwiched together to support the rafters, with a butt joint in the dead center of the shop. To support the sandwiched 2x8 butt joint, there is a column of 4 4x4 posts. (I'll try to post pics later...at work right now)
The column is killing me. Even when I had the BT3100, I could barely walk around it because of the column. I can't crosscut a large piece of wood easily, no matter where I put a table saw.
I was thinking of a couple of options to remove the column. One is to somehow strengthen the 2x8 butt joint with steel plates and carraige bolts and hope that holds.
Another would be to somehow put a couple of 20' 2x8 in place of the current 2x8s. Don't know how I would fit it in, unless I came in through the outside. Pics will explain better. I'm afraid that the 20' span would be too much and would cause the 2x8s to split.
The other options I can come up with are to replace the sandwiched 2x8s with a wood i-beam, or to sandwich a wood i-beam up next to the existing rafters. I'm not too concerned with how it would look, but I want to make sure the roof will hold up, especially since it was redone in late '06 or early '07.
What are y'all's thoughts on this? Also, does anyone have a clue as to how much a 20' 8" thick wood i-beam would cost?
Thanks!
Thanks!
