router table upgrade
  • Salty
    • 690
    • Akron, Ohio
    Using more parts from the accessory kit, I was able to upgrade my table.
    The biggest improvement was replacing the plastic inset plate with a 1/4" aluminum plate.
    I managed to duplicate the cutout that is in the BT3 extension table so that I can use the red inserts as well. Sure did improve the results of my routing operations. The plastic plate was beginning to sag from the weight of the router.
  • Duff
    • 164
    • San Antonio, TX
    • Enco 12" RT
    Is that the Craftsman fence there too? Do you have a miter slot in the table? Got a better shot of the whole deal?
    Enco 12" RT table saw(with router table currently added to right wing), Central Machinary 6" jointer, Delta 16" (17-900) drill press, Ridgid 14" bandsaw, Jet bench top Mortising machine, Porter Cable 6901 series routers (2) and a wide variety of Ryobi 18v tools.
