Last spring I decided that it was time to build a new large assembly table for my workshop. When deciding on what kind of construction to use, the design of simple shop carts caught my eye. It is easy to tell that they are very useful, as they are always piled high with parts for whatever project is being built at the moment.
I set a sheet of plywood on a shop cart to help determine just what size the new table should be, and ended up with 40” x 80”. However, this simple project can be built in any size that you have room for in your shop. I build all workbenches to a standard 36” high, so that is how high the table is.
Basic construction uses 3/4” plywood legs shaped like angle iron, and they are strong! Top and bottom stringers are 4” wide, and as you can see the construction couldn’t be simpler. I needed a large shelf under my table, but the area could just as easily been filled with drawers. As a matter of fact, I did add one drawer after finding a single set of left over drawer slides.
