Do any of you use the router setup on the BT3 for dado cuts?
I was thinking of setting it up for those times when I need to dado a slot on a panel.
My router table doesn't allow a lot of distance from the bit to the fence but a setup on the BT3 could go 2 foot or more. I have the accessory pack so I have all the parts needed. I just don't know if it would be worth the trouble.
I also looked at using the aluminum plate from the kit in my homemade router table but it is a much different size than the cutout I already have and the plastic inserts only fit the accessory table on the saw. Got some nice knobs and hardware though that can be used for other jigs!
