Well, I finally used half of the old kitchen counters to make a work bench.
The miter saw on the side was a bit of an after thought. I had some used folding brackets that I used to use as a workbench in a small garage. I used them with a 15" wide piece of the countertop. Adding the 1/4" pieces under the CMS brings it to the same level as the bench. It is about 35" high so it is much more comfortable to work on than the BT3 deck.
Once I get to building something I'm sure I'll be drilling hole in it to position some stop dogs cause it is slippery! But it is also heavy and solid to work on. May need a coat of paint too!
