Router table questions...
    Going against the specific question that you asked about using a miter slot for feather boards, - last week, I used the miter slot gauge and miter on my router table.
    I had 3 boards 1/2 in thick, 2 inches wide and 12 inches long. I needed a round bottom slot across the width of each about 1/2 in from each end. Hard to do by hand, and even using a fence. Also hard to use a jig for such a small piece - in order to use the router on top. The Quickest way was to use the miter slot and miter guage. Worked fine.
    As to your specific question, I have used feather boards in my miter slot for long pieces - 4 to 8 ft pieces used in making mouldings and picture frames. It is very hard to make smooth pieces for mouldings and picture frames from long stock without a feather board. At least I have not developed that kind of skill yet, - but I don't do this as a day job either.
    • RodKirby
      • 3136
      • Mao Shan TSC-10RAS
      You're right, Hank (& others).
      I've never had a job that needed something > 3' long. I would certainly use featherboards (down & in) for something "big".
      Downunder ... 1" = 25.4mm
