I need help settling a 'discussion' I'm having with a friend, please.
Case 1:
Electrical power (220 volt) to a detached building is from the main panel in a house, currently from a 60 amp breaker, to a 100 amp distribution panel (max 45 amp usage at any one time) in the detached building. Underground cable of the correct size.
Should the ground conductor be connected to the Ground/Neutral bar in the main panel in the house and to the ground/Neutral bar in the panel in the detached building, or should it not be connected in the main house panel and a dedicated ground rod be driven at the detached building and that ground used for the 100 amp panel in the detached building.
Case 2:
Same situation except that the supply to the detached building would be from the meter box on the house. Would one use the ground in the meter box or a ground rod at the detached building.
In both cases the building is ~75 feet from the house.
Thanks
Case 1:
Case 2:
Thanks
