Penny wise, pound foolish garage cabinets
    When we bought this house and detached garage, I immediately saw my new
    shop and where I wanted everything. I knew I wanted a bench with
    mitersaw. I started these last November after I insulated and walled up the
    shop. After a trip to the Habitat for Humanity Restore, I bought these
    cabinet doors for $5 each. I figured it would save me a lot of time and
    money. They were already drilled out for hinge cups, too. I planned the
    cabinets around the doors.
    Upper cabinets were a piece of cake. Melamine sides and oak face frame and
    adjustable shelves. Glued and screwed cabinets. These came out perfect for
    me.
    Lower cabinets a whole different story. Problem 1) the 2 doors make the
    bottom cabinet 50". That one sheet of plywood for the back just became 2.
    Problem 2) I also somehow screwed up the location of the partition on both
    cabinets. So not only did I need to make slightly different width drawers for
    each door side, but I also needed to shim the slides because the partition
    also made the cabinet deeper in the back and skinner in the front and vice
    versa. I found this out AFTER making all the drawers. I ran out of oak, so
    for now no drawer fronts. Started in November, I'm calling it done now.
    Bench tops are salvaged laminate I brought back from work. They are half
    lapped 2x4s underneath and banded with oak. The portion that holds the
    mitersaw is scrap from this build. It's held in place with T-nuts and bolts. I
    need to work on a system to catch all the dust now.
    Paul
    Your story sounds eerily like how my projects have been going lately. Except your project results in something very nice looking and serviceable!
    Good job,
    • TheRic
      • Jun 2004
      • 1912
      • West Central Ohio
      I know where you are coming from. More than once I got something dirt cheap, then spent more money getting it to work then if I bought the actual item brand new.
      I usually look at it when I'm done and ask myself what did I learn from the project (other than the waste of money). If I learned something then I chalk it up as a experience / a lesson learned / etc.
      If I didn't learn anything, then I kick myself several times.
      If you don't like them then I will be happy to put them in my garage. They would definitely be a step upward from what I have.
      Ric
        Everything looks great. Can't tell there was a problem. What helps a lot is to make sketches of the cabinets, mark the drawing and the pieces with corresponding numbers or letters. On the actual pieces, which should match the drawing, measure off and mark what gets what. I can't emphasize the importance of the paperwork. I don't trust much to memory. Actually it's a great habit to get into. I save all paperwork to all work.
        When I have developed a certain procedure to solve a problem, it's saved, so I don't have to figure it out all over again. I also have to index the jobs and procedures so I can find what I'm looking for in the mass of paperwork.
          I wish all my mistakes looked that good. Nice job.
          • MilDoc
            OK. So, when can you visit and build mine?
