220 v Installation
  • Greg in Maryland
    • 250
    220 v Installation
    Hi
    I need to install a 220 v outlet right next to my circuit breaker for a compressor. I have plenty of slots left in the circuit breaker and the wiring needed for the outlet should be less than two feet.
    Anyone have any idea what a licensed electrician would charge me for this job? I realize that this answer is completely dependent upon location, so I am just trying to get an rough idea.
    Thanks.
    Greg
    Originally posted by Greg in Maryland
    Hi
    Thanks.
    Greg
    Greg, sent you a PM.
    If you get all the parts and supplies for him and you don't have drywall to
    mess with or you prep the wall beforehand, it should be less than a 1/2 hour
    job. You'll have to pay him for travel time, too. I'd think $50-$75 for
    starters.
    Paul
    • TheRic
      • Jun 2004
      • 1912
      • West Central Ohio
      First: It's a Panel Box, not a circuit breaker. The panel box HOLDS the circuit breakers.
      Second: I would guess $50, that is a number I pulled out of the air. There might be a minimum price or time you might have to pay. About $25 for the material.
      Ric
      • JSCOOK
        • Sep 2006
        • 774
        • Kitchener, Ontario, Canada
        • Ryobi BT3100-1
        Don't forget the cost of the "permit" or whatever is required in your location as I'm guessing it will have to also be "inspected" if your having an Electrician do it ... he's not going to risk his license in most cases.
        If you understand whats involved and understand what safety precautions need be taken, I'd just do it yourself since it's so simple a job ... otherwise do have any buddies that are good (and competent) with wiring?
        • Crash2510
          • 830
          • North Central Ohio
          In Ohio this kind of thing is typically not inspected
          Phil In Ohio
          The basement woodworker
            For insurance purposes, you should have it inspected. However, I wouldn't for
            something like this, and the past 2 electricians I've worked with on both sides of
            the country both didn't seem the need for it. By the time the inspector shows
            up, all the work is tucked away behind the walls, he looks around, flips the
            switch, asks a few questions, and signs off on it.
            Paul
            • sbs
              • Mar 2005
              • 126
              • VA
              • BT3.1k
              Hi
              This is an absolutely trivial job. If you are at all mechanically inclined you should do it yourself.
              If you hire someone, the trip charge will be the main cost. Trip charge + 1/2 hour labor + materials. Probably $100-150 in most parts of the country.
              • Jeffrey Schronce
                • 3822
                • York, PA, USA.
                • 22124
                Paul
                There is nothing "insurance related" about the job. If he were to make a mistake that caused fire, etc then your homeowners would respond and pay your damages, as well as, look into the matter of subrogation (recovery from adverse party).
                Not sure where you are in MD, but I am going to agree with the $100 - $150 price range. Most of that will be the trip out.
                I do agree with the other poster that they are pretty easy to install yourself. I have installed 3 220v double pole breakers, outlets and plugs on the machinery and its a pretty simple process.
                • Rand
                  • 492
                  • Vancouver, WA, USA.
                  It is pretty easy. How many amps does the compressor require? I ask only because as the amperage goes up the wire diameter goes up too. I'm guessing a 20A breaker would be enough. In that case you use 12g wire.
                  Just make sure you turn the power off to the panel before you start working on it.
                  Rand
