Metal shavings and DC
  • newood2
    • 600
    • Brooklyn, NY.
    When cutting or drilling metal on a mitre saw or drill press, is it ok to use the DC or shopvac?
    Is there a danger sucking up metal shavings and filings?
    Howie
  • Popeye
    • 1848
    • Woodbine, Ga
    • Grizzly 1023SL
    Has never caused a problem for me. Pat
    • Wood_workur
      • 1914
      • Ohio
      • Ryobi bt3100-1
      as long as your DC doesn't have a plastic impeller. (If it does, use one of those 2-stage adaptors)
      Alex
      • ejs1097
        • Mar 2005
        • 486
        • Pittsburgh, PA, USA.
        I understand that this can be a fire hazard. If the shavings are hot (and they usually are) and there is sawdust in the DC you can easily start a fire.
        http://www.ridgidparts.com/pdf/DC50500.pdf#search='metal%20shavings%20dust%20coll ector%20fire'
        http://www.woodworkingdustcollection.com/page4.htm
        Eric
        Be Kind Online
        • Stytooner
          Roll Tide RIP Lee
          • 4301
          • Robertsdale, AL, USA.
          When I am sanding metal, I don't turn the collector on when sanding, but only afterward. The metal has had a chance to cool by then. Not good to be sucking up sparks.
          • bigsteel15
            • 1079
            • Edmonton, AB
            Very true...from experience.
            I will use a clean bag (or no bag) next time in shop vac
            Brian
            Welcome to the school of life
