Crouch Stool
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    Crouch Stool
    One for us oldies…
    Do you sometimes find it hard to get up from a crouch? I sure do. The old knees ain’t what they used to be!
    For example, I need to get under both my Router tables to raise/lower the routers and to lock them once positioned – I prefer to do it this way rather than use a “raizer”.
    Height (important) 14” – for me this is about 3” below my knee, seat 17-3/4” x 15” (360mm, 450mm x 380mm).
    Base is Clear pine, seat is ¾” MDF. ¼” chamfer all over both.
    Base is (woodhaven) biscuit joined, Titebond II glued – no hardware, rubber feet. 3 coats of Clear Poly finish. Not pretty, but it sure does ease the pain.
    Edit: Version 2 on the right. Same dimensions, slightly smaller top and only 1/2" instead of 3/4" MDF. Base only about half the size of clear pine. MUCH lighter and plenty strong enough.
    I discovered the the first version was way over-engineered! And too heavy. I'm sure a 500lb Gorilla could stand on it.
    (BTW If I'd known I could get a "mobile mechanics seat" I could have saved a HEAP of money! But then I wouldn't have had so much fun - and - I think this looks better )
    Downunder ... 1" = 25.4mm
    Using MDF for the seat ...Where would you come up with an idea like that????
    • GeekMom
      • 752
      • Bonney Lake, WA.
      • Shopsmith Mark V
      Great idea, Rod! And it looks good to boot.
      Karen
        Rod, is it bad that I have issues with that and I'm not old?? It's not the years, it's the milage. And the milage on the bike sure doesn't help. :-D
        Good job, is it comfy?
          Rod
          Great idea and good looking too. I can see two advantages to it. First, I would most likely fall asleep, after getting situated. Second, to cut a hole in the center, place over bucket, and I wouldn't waste time running off to the b/room. Seriously, I made a short bench, about 12" wide and about 24" long pretty much the same height, that did duty like that, doubled as a step stool, cutting surface for hand saw, circular saw, stand for anything that had to be proped up, tool box of sort (had a lower shelf), place to set one foot while drinking coffee wondering why I cut that last piece 1/2" too short, and a place to set things while drying. Had many uses and I cut a hand slot in the center to carry it around. I moved it so much in the shop I should have mounted a belt clip on it.
          • jabe
            • 583
            • Hilo, Hawaii
            Great idea & good looking, I have the same problem crouching, the old body aint what it used to be. Man your shop looks clean!
            • Popeye
              • 1848
              • Woodbine, Ga
              • Grizzly 1023SL
              Pretty sharp as always Rod. Pat
              • RayintheUK
                • 1792
                Rats - I was expecting the top to be hinged, revealing a storage space containing brass and chrome polish. Obviously one of your quicker jobs, eh Rod?
                Ray.
                Did I offend you? Click here.
                • RodKirby
                  • 3136
                  Ray.
                  I was thinking I could do a David Marks "This was the prototype" - and then: Slot in the middle for carrying, tapered legs, etc.
                  I DID think of the storage space, but I was worried about the weight
                  Didn't want to wreck my back to save my legs
                  • hobkirk
                    • Jul 2005
                    • 85
                    • Acton, MA, home of the original Minuteman - about 20 miles West of Boston
                    Thank you Rod - entertaining as always!
                    PS - After 40 years of distance running, 25 years of squash, and 3 knee surgeries, I can't crouch! I have several short "stools" I use when I need to stay down longer than is comfortable on a rubber kneeling pad.
                    Doug Hobkirk
                    WOOD LOON
                    • RodKirby
                      • 3136
                      Version 2 in progress...
                      • hobkirk
                        • Jul 2005
                        • 85
                        • Wouldn't it be more convenient if you could call it and it would come and slide directly under you wallet?
                        • Or maybe if it automatically sensed when your wallet started descending...(better contact Loring for electronic advice...
                        Smart-alecks like me should be outlawed!
                        Good luck - and I'm looking forward to seeing version II - you really do add make this forum more fun!
                        Doug Hobkirk
                        WOOD LOON
                          • 8805
                          If we could somehow glue it or tie it to our bottoms so that it would be there everytime we need to stoop over / crouch.
                          • scmhogg
                            • 1839
                            • Simi Valley, CA, USA.
                            Rod,
                            I have a couple of the mechanic's roller seats that I got from HF. They are invaluable when I have to work in my lower cabinets. They wouldn't make much of a step stool, with the wheels. But, you can scoot from one low cabinet to another.
                            http://www.harborfreight.com/cpi/cta...emnumber=37762
                            Steve
                            • RodKirby
                              • 3136
                              Originally posted by scmhogg
                              Rod,
                              Steve
                              Thanks Steve. That would have been perfect - and GREAT price. Never seen anything like in Oz but no doubt they're around.
                              Aaarrrrgggghhhh:
                              http://cgi.ebay.com.au/MECHANICS-WOR...QQcmdZViewItem
                              AND I've nearly finished V2.0
