Triton Router table DC (Ray!)
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    Thought these would show the DC more effectively.
    Short connection from the router shroud to the side of the table ("permanent"), then normal Shopvac connect to the outside of the table:
    Rear of the fence with Kirby's (old) DC port. Not pretty but it works!
    Downunder ... 1" = 25.4mm
  • RayintheUK
    • 1792
    Thanks for that, Rod. I was wondering whether the fitted shrouds made a difference, compared to the Ryobi.
    The micro adjuster looks to be in the ideal position now - don't see the need for the above-table winder accessory in that configuration.
    My tables are just inserts within lift-up flaps, so DC is a bit hit and miss. I've built a plenum chamber in my fence that's great with a suitable bit, but routing dados still shoots all the dust out of the left side of the slot, even with the DC connected below the table. I think I'll try removing an insert ring to see if that helps in that situation.
    Thanks again for the pics.
    Ray.
    Did I offend you? Click here.
